12-14-2018, 08:57 PM | #21 | |
Re: Secret of Speed Article about distributor rotors "UPDATE"
12-14-2018, 09:07 PM | #22 | |
If you can, get your mechanic to let you watch ignition traces on his scope. Or check out an evening class at a community college. Notice the time it takes for each ignition event. |
12-14-2018, 10:48 PM | #23 | |
Thanks for the info. |
12-15-2018, 09:02 AM | #24 |
40 Deluxe, Can you explain to me exactly how the points work. For years, I believed that the spark was generated when the points closed and contacted. For the last few years, I've rethought this, and believed that the spark occurred when the points opened. There has to be buildup of voltage in the coil and the capacitor This is what the dwell is for, to give it a millisecond to build up the voltage. Am I correct?
Terry |
12-15-2018, 12:29 PM | #25 |
40 Deluxe - After re-reading these posts and looking elsewhere, one question. why is this gap checked/adjusted?
A larger gap creates a higher voltage before spark occurs, just do not understand how the gaps (Plug + rotor) affects combustion. Am a little OCD on details. Thanks |
12-15-2018, 04:31 PM | #26 | |
Dwell is the amount of time, expressed in degrees of rotation, that the points are closed. |
12-15-2018, 04:52 PM | #27 | |
When emissions standards came about, fuel mixtures were leaned down considerably. But it took a larger gap to fire this lean mixture (fewer fuel molecules within the plug gap, thus a larger gap was needed, like .045"-.060"). The larger gap required higher secondary voltage so better coils were needed. This lead to thicker plug wires, bigger caps, etc. The higher current is harder on points, plus the ignition system had to last longer between 'tune-ups'. Thus the changeover to electronic ignitions. |
12-15-2018, 05:03 PM | #28 | |
Thanks for the taking the time to provide the details. I do have an electronics background, but not automotive theory. Knowing why I am doing something instead of blindly following a procedure reinforces the info, and helps me remember the correct way. |
12-15-2018, 06:52 PM | #29 |
With your electronics background, you might like searching for "automotive ignition scope patterns". One sample pattern shows spark duration to be one millisecond. The rotor in an idling Model A engine won't move very far in one millisecond, so I don't think rotor gap would affect ignition timing, nor would even a big variation in rotor gap affect timing to the slightest degree. To illustrate how quickly ignition events take place, I drag race a Mercury Cougar with a 289 engine, single coil ignition. I shift around 7500 RPM, which calculates out to 500 sparks needed per second, or 5 sparks every 1/100 sec.!
12-15-2018, 09:22 PM | #30 | |
Thanks For taking the time to explain it! It is much appreciated.
Terry Quote:
12-16-2018, 09:38 AM | #31 |
Thank you 40 for your time and expertise.
12-16-2018, 10:35 PM | #32 |
Thanks for all the comments and information on this
I learned a lot. Joop |
