08-14-2015, 06:53 PM | #1 |
The "Ahhhhhh" feeling.
At last had the Ahhhhhh feeling today!
With the new Mitchell overdrive installed went for a ride. Quite nice to slide it into high and feel the engine relax A little. Been waiting to do this for sometime. Worth the wait. Gil. NoCal |
08-14-2015, 07:01 PM | #2 |
Re: The "Ahhhhhh" feeling.
It has been a long wait for me also, but mine should arrive this week Can't wait to experience the AAAAAH feeling. I'll start removing the Diff. on Monday in preparation.
Adjust your points with gentle blows of a 2 pound hammer |
08-14-2015, 07:25 PM | #3 |
Gee....I thought I heard something earlier today while driving my transit bus. Was that you and you're 'ahhhh'?
Glenn |
08-14-2015, 07:27 PM | #4 | |
A Mitchell overdrive is the best thing you can do to improve the Model A for long road trips. You will ask your self why did I wait so long. enjoy Don
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
08-14-2015, 09:35 PM | #5 |
If you felt an Aaahhhhh moment, imagine how your engine feels.
08-14-2015, 10:01 PM | #6 |
Want the new touring engine to be happy....and last. Gil. NoCal |
08-15-2015, 01:33 AM | #7 |
lots has been written about the two gear ratios, which did you get high or low?
08-15-2015, 02:32 AM | #8 |
Thanks Don, as you know we have some vast distances to cover and I'm not shy in doing the necessary distance to attend our National Meets. I have had the 3.54/1 diff ratio which was a big improvement over 3.78. I'll see how it goes with the 26%overdrive and if it proves to be to tall I have a standard diff to install if required. I am running a B Motor with a counter balanced Crank and it does pull strongly so I'm hoping to leave the 3.54 ratio in, time will tell.
Don, please give Anita a hug for Cheryl & I. We have missed you at the last couple of meets.
08-15-2015, 04:46 AM | #9 | |
08-15-2015, 04:59 AM | #10 | |
08-15-2015, 05:37 AM | #11 | |
Chuck McDonald, Member of AACA, Model A Club, NRA |
08-15-2015, 05:43 AM | #12 | |
08-15-2015, 07:02 AM | #13 |
We also have the 3:54 and got tube 26% OD.
Like has been said....nice feeling @50-55mph. Gil. NoCal |
08-15-2015, 01:04 PM | #14 |
Nice reports on the Mitchell.
I'd like to install one also. Thanks for the info - either the 3.78 or the 3.54 works well with the 26% OD Al |
08-15-2015, 02:16 PM | #15 | |
Since you are new to this equipment use, I wonder at what rpms you are shifting into od ? Is it just going by ear thing or do you have a tach ? |
08-15-2015, 02:41 PM | #16 |
Some guys with PINTO motors, put in a MITCHEL, BACKWARDS, to get up our STEEP SIERRA MOUNTAINS!
Bill W.
08-15-2015, 05:04 PM | #17 |
Bill, I've got to ask, are you serious or are you just being Bill Williamson the joker. I guess whatever your reply is I suspect I will be left wondering.
08-15-2015, 06:15 PM | #18 |
No teach in the Icky.
Shifting by feel....just like I did without the OD. Bottom line....doing the 45-55 the engine is just running easier. Hopefully that equates to longer lasting. Very sure it was worth the wait....and $$$$. FYI....Mitchell must be doing something right.... They are booked 13 weeks out making these OD! Gil. NoCal |
08-15-2015, 08:54 PM | #19 | |
I wouldn't joke about something like that & mislead someone. Ted's Coupe is set up like that, used as an UNDERDRIVE, WITH THE SMALL DISPLACEMENT ENGINE, for mountain climbing. A stock Model A is a BETTER MOUNTAIN GOAT! Minerva, with her Weber & single point Mallory, was a VICIOUS mountain car & we have some REAL MOUNTAINS here! Model A with a Pinto is fairly good on flatland, except in head winds, as it is a HIGH RPM engine, too bad it is ONLY 121 Cubic Inches. Bill W.
08-16-2015, 12:20 AM | #20 |
This must be the Pinto (Ford Cortina/Escort) engine you mention.
http://www.engineswapdepot.com/?p=2771 Does seem a little under powered ... |
