04-24-2013, 05:52 PM | #1 |
"NEW" reproduction oil pump VS original
Hello to all you mechanical guys out there: in trying to find a good original oil pump core for rebuilding, I have struck out the last 4 times trying to get something worth rebuilding. At this point between the cost of the cores and the cost of the shipping, I am nearly at the point of the reproductions that Brattons & others offer in their catalog. Have any of you bought & used one of these - have you taken one apart to inspect it; quality of the gears, machine work and tolerances that would provide a good supply of oil for a rebuilt engine. I hope that someone can shed some light on this issue. regards, Steve
04-24-2013, 06:02 PM | #2 |
Re: "NEW" reproduction oil pump VS original
I rebuilt an original pump that I thought was a good core, and when I tested it by running it on my newly rebuilt engine, it took well over 2 minutes to get oil to flow out of the oil return tube (I had cut up a spare return tube and installed a section of clear 3/4" ID rubber tubing to see the flow). I thought that was way too long, so I purchased and installed a new pump from Bratton's and I then had oil flowing in 25-30 seconds. So I'm definitely OK with the new pumps.
04-24-2013, 06:22 PM | #3 |
We reviewed the new pumps when they first came out. We still have one in the roadster and it is putting out good pressure and is holding up very well.
04-24-2013, 07:07 PM | #4 |
