11-14-2012, 02:22 PM | #1 |
Another Rust Remover
Last night I did a Google search looking for an owner's manual for my Adler 187 sewing machine. I came across this site where the guy bought a rusty Adler 187 from craigslist and removed the rust with Lime Away. It looks good from his pictures.
http://yarnhog-yarnhog.blogspot.com/...een-doing.html Last edited by Tom Wesenberg; 11-14-2012 at 09:37 PM. |
11-14-2012, 06:39 PM | #2 |
Registered User
Re: Another Rust Remover
i believe lime away is nothing more than hydrocloric acid
same thing as muriatic acid ,except you can buy muratic acid a lot cheaper dont know why they call it muratic acid when its just hydrocloric acid |
11-14-2012, 07:49 PM | #3 |
You can find the MSDS online: lime away msds. This is from wikipedia: Sulfamic acid is used as an acidic cleaning agent, sometimes pure or as a component of proprietary mixtures, typically for metals and ceramics. It is frequently used for removing rust and limescale, replacing the more volatile and irritating hydrochloric acid, which is however cheaper. It is often a component of household descaling agents, for example, Lime-A-Way Thick Gel contains up to 8% sulfamic acid and pH 2 - 2.2,[10] or detergents used for removal of limescale. When compared to most of the common strong mineral acids, Sulfamic acid has desirable water descaling properties, low volatility, low toxicity and is a water soluble solid forming soluble calcium and iron-III salts. The question with any chemical treatments is what is left behind that might cause you problems in the future. I do not know the answer for this product. |
