Old 08-11-2020, 09:05 PM   #1
harleycontracter
Default Headlight mounting???
PLEASE DELETE Can't figure how to post pics
harleycontracter is offline   Reply With Quote
Old 08-12-2020, 10:51 AM   #2
30 Closed Cab PU
Default Re: Headlight mounting???
Most pictures taken electronically today have a very large file size. There are limitations on how large a picture file that can be posted.
On Windows
File size check - Do not open, right click on a picture, click on properties. If it is more than 1 Megabyte, resizing is needed.
To resize - Do not open, right click on the picture, click on resize, then change the size from 100 to around 25. Save.
30 Closed Cab PU is offline   Reply With Quote
Old 08-12-2020, 11:01 AM   #3
Bill G
Bill G's Avatar
Shouldn't the forum software be able to size accordingly? Thought I'd ask because the size issue on this forum has kept me from going through the steps to resize. I just move on. Probably others too.
Bill G is offline   Reply With Quote
Old 08-12-2020, 11:28 AM   #4
30 Closed Cab PU
I do not think it does. The moderator Ryan would be the one to answer. I've seen this on other forums too.
Old 08-12-2020, 06:45 PM   #5
redmodelt
redmodelt's Avatar
Without knowing what the problems were, would be hard pressed to offer suggestions. I will say, check the Questions and Suggestions sections, there have been a couple of questions there of late. Also if you want to practice, that is what the Test Forum is for; https://www.fordbarn.com/forum/forumdisplay.php?f=13
Old 08-12-2020, 09:05 PM   #6
shew01
shew01's Avatar
If you use Tapatalk on an iPhone, Tapatalk will prompt for resizing photo uploads.
shew01 is offline   Reply With Quote
