Old 10-22-2019, 11:00 PM   #1
Robin 47 ford pickup
Default 1947 1 ton pickup front brakes
Hi guys , can anyone tell me if the front brake backing plates with the adjustments on the base of the shoes give any better braking performance than the plates with the shoes fixed at the bottom on a 1947 1ton pickup ??? I have both setups , just wondering which way to go.
cheers Robin
Robin 47 ford pickup is offline   Reply With Quote
Old 10-23-2019, 07:19 AM   #2
corvette8n
corvette8n's Avatar
Default Re: 1947 1 ton pickup front brakes
The bendix type brakes with the floating shoes work better than the Lockheed type if that's what your asking. Search this forum for information on both types.
Post some pictures of your truck it sounds interesting.
Old 10-23-2019, 04:57 PM   #3
Ok , I realize now i have Lockheed brakes , so what I want to know is are the better brakes the ones with the cam adjustment at the bottom of the shoe or the fixed pins. And how do I post photos of my truck?
Old 10-23-2019, 08:42 PM   #4
JSeery
JSeery's Avatar
Biggest issue with posting photos is the file size. There is a maximum of around 585k. You need to reduce the file to less than this limit first. To post click the advanced tab, then the paperclip on the advanced page. It will get you to a pop-up that lets you select the file to upload.
Old 10-23-2019, 09:21 PM   #5
alanwoodieman
best in my opinion is adjustable pins, easiest to set up are the fixed pins-but these require a "fitting/running in" scenario to make them work. newer floating shoes do work the best
