Old 02-26-2019, 03:22 PM   #1
BillW810
BillW810's Avatar
Default 1939 Ford windshield frame
I bought a w/s frame that was already apart. I am making the inserts that hold the top and bottom together. I was told that the inserts are not straight. It looks like straight works. Do they have a bend or are they straight?
Thanks
BillW810 is offline   Reply With Quote
Old 02-26-2019, 09:06 PM   #2
swoopNZ
Default Re: 1939 Ford windshield frame
If you mean the 2 square pieces at he sides - straight.
Well it looks straight to me.
swoopNZ is offline   Reply With Quote
Old 02-26-2019, 10:23 PM   #3
BillW810
BillW810's Avatar
Yes they are inside the frame 5/16" square and about 3.5 inches long. 4 screws in each that hold the frame together where it splits to put the glass in.
Thanks.
Old 02-27-2019, 12:43 AM   #4
rich b
rich b's Avatar
I have pair of bars sitting here and they have a slight side-to-side bend to them. I salvaged them out of a junk '37 or so windshield for a future repair to a chrome frame someone went overboard drilling out stuck screws.
rich b is offline   Reply With Quote
Old 02-27-2019, 09:23 AM   #5
BillW810
BillW810's Avatar
Well thanks. It can't be much of a bend it does go together with them straight. I lined the top and bottom. I think I figured the bend.
Thanks
Old 02-27-2019, 07:26 PM   #6
rotorwrench
rotorwrench's Avatar
If it fits together and fits the windshield opening then it's good to go.
rotorwrench is online now   Reply With Quote
Old 02-27-2019, 08:10 PM   #7
Lanny
Lanny's Avatar
If I remember correctly, the '37 and '38 closed cars and pickups, where the
upper and lower windshield frames connected at about the middle of frame.
In about July '38, Ford changed the connecting point of the upper and lower
w/s frame to connect closer to the bottom, about 2/3's the way down
from the top of the w/s frame, and carried that thru 1939.
Maybe (I don't know for sure), one style used straight, and one style used
slightly curved insert connectors ???
I live on tuff street, the further ya go,
the tuffer they git,
I live in the last house on the block !!!
___________________________________________
You bet ya, I wear the pants in My family --------
So What, if She tells me which ones to wear ?
Lanny is offline   Reply With Quote
Old 02-28-2019, 10:15 AM   #8
1936 ford pickup
HELLO....I hope this helps someone somehow.
I have a '36 Ford pickup and after trying different things "forever" to separate the top and bottom halves of the windshield frame, I decided to "split" it. I removed the two seam clips and then measured center to center on the windshield screws. I then split on the water jet. Then turned the two windshield frame pieces upside and placed into vice on mill. I plunged down with an end mill to remove the old rusted/stuck inserts without destroying the windshield frame pieces. I fabricated new stainless steel inserts and #10-32NF tapped the holes.
Bruce Smith
Modesto, Ca.
1936 ford pickup is offline   Reply With Quote
Thread Tools
Display Modes
