Old 01-09-2022, 05:16 PM   #1
modela4shane
Default 59a main cap studs or bolts question?
I have a 59A in the machine shop that has its main cap studs and nuts missing. I'm curious on your thoughts on using bolts instead of studs with nuts. Speedway sells ARP main cap bolts and washers for a reasonable price. Ford used bolts on the 8BA but im not sure if it would be safe to do the same on a 59A. Thoughts or experiance would be appreciated on this issue.
modela4shane is offline   Reply With Quote
Old 01-09-2022, 05:34 PM   #2
Ronnieroadster
Ronnieroadster's Avatar
Default Re: 59a main cap studs or bolts question?
Replacing the studs with bolts is what I always do on the 59A engine's I build. On some highly modified flathead builds I will use ARP studs and their washers and nuts for the main bearing caps.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is online now   Reply With Quote
Old 01-10-2022, 01:13 PM   #3
Bored&Stroked
Bored&Stroked's Avatar
One thing to note - when you change the main cap hardware, make sure they check the main bores. Sometimes one has to align bore/hone the mains when the hardware has changed. If you have the original caps, the chances are you'll be okay - just make sure they check everything with the final hardware that you plan to use.
I typically use ARP main studs/washers/nuts (high performance builds) - as I like to torque on the fine threads (top of studs) and not on the coarse threads that are in the block.
Old 01-19-2022, 02:16 PM   #4
modela4shane
Thank you for the replys. Would you happen to have the ARP numbers for the studs, washers and nuts that you used from ARP. Thank you.
Old 01-19-2022, 02:23 PM   #5
Bored&Stroked
I just buy a kit from Red's Headers:
https://reds-headers.net/index.php?m...q5e2dr0tpk5g86
