Old 01-18-2018, 11:35 AM   #1
JohnB15632
JohnB15632's Avatar
Default Engine Pan Installation
I am trying to install the engine pans.
The pans come with three home on the outboard side the secure to the frame underneath.
On the engine side, there are two tabs with slots. Am I to loosen two bolts that hold the engine pan to the block, slide the tab underneath, and resecure the bolts.
If this is wrong, where do the two tabs of the engine pan connect?
Thanks,
JohnB15632 is offline   Reply With Quote
Old 01-18-2018, 11:50 AM   #2
redmodelt
redmodelt's Avatar
Default Re: Engine Pan Installation
Yes the tabs on the engine side go under the pan bolts.
Old 01-18-2018, 12:40 PM   #3
Bob C
Looks like your light switch is upside down.
Bob
Old 01-18-2018, 12:45 PM   #4
aermotor
You might want to put a couple washers under the tabs as thick as the oil pan flange lip.
John
aermotor is offline   Reply With Quote
Old 01-18-2018, 12:56 PM   #5
BillCNC
BillCNC's Avatar
My car did not come with pans when I bought her but I have some now that I am going to be installing here shortly. I have a couple of questions about the pans themselves.
With them being mounted to the frame as well as the engine, ... do the flex and become prone to metal fatigue around the mounting points?
Does the paint crack in the mounting point areas?
Regards
Bill
BillCNC is offline   Reply With Quote
Old 01-18-2018, 01:22 PM   #6
DougVieyra
DougVieyra's Avatar
Bill, to answer your question - yes, they do flex and become prone to cracking and breaking. However, that being said, it does take several decades of driving for anything significant to happen, so it is nothing to worry about. After 30 years of constant driving, IF and When it becomes a problem, simply buy another set. Most of us will never see the problem - only the next generation of drivers will ever be subject to the possibility.
DougVieyra is offline   Reply With Quote
Old 01-18-2018, 01:50 PM   #7
duke36
The right side pan with the exhaust pipe slot might need to grind the flange a little to clear one of the right side forward oil pan bolts. That was the only pan conflict we found. You also may need to compress slightly the pans to fit. We cut little slots in the 6 frame bolts threads ends to receive a screwdriver to hold when installing the square nuts (facing down). The oil pan bolts secure the pans at 4 places. Also, even with powder coat, prolonged gas leaking from the carb may eat the finish. Some use lacquer or dope in that area.
Old 01-18-2018, 02:24 PM   #8
BillCNC
BillCNC's Avatar
Thanks Duke,
Sounds like nothing to worry over but I wonder if putting a rubber grommets with a steel insert at the mounting points would help.
Regards
Bill
Old 01-18-2018, 02:48 PM   #9
JohnB15632
JohnB15632's Avatar
I did get the pans installed. I will tell you that it was not easy task. I had to use clamps and a pry bar to install the pans and get the fasteners inserted. It is not easy to be sure.
Thanks,
Old 01-18-2018, 04:49 PM   #10
wrndln
The light switch, besides being upside down as pointed out above, actually has a later cap on it. Model A light switch covers did not have a flat area on them.
Rusty Nelson
Old 01-18-2018, 06:56 PM   #11
redmodelt
redmodelt's Avatar
Re light switch, that is how most current replacements are made. It is the V8 style.
Old 01-18-2018, 07:12 PM   #12
JohnB15632
JohnB15632's Avatar
Thanks for the heads up. I will change the cap out tomorrow. I will not be getting to wiring the vehicle for quite a while.
Thank you.
Old 01-18-2018, 08:47 PM   #13
glenn in camino
glenn in camino's Avatar
If you' not building a show car, try drilling the holes in the frame a little bigger and threading them for the bolts. Makes installation easier.
Old 01-18-2018, 08:59 PM   #14
JohnB15632
JohnB15632's Avatar
To Glenn,
Thanks for the suggestion. I was able to install the pans. It was difficult, but with a tremendous amount of persuasion, I install all five fasteners in each of the two pans. Not a job I want to do again, I am sitting here on a heating pad, trying to warm my back. Apparently, laying on a cold garage floor in not good for this old man!!!!
Thanks!!!
Old 01-18-2018, 10:22 PM   #15
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Dog here,
Even Dogs have enuff common sense than to lay on a COLD floor! In human years, I'm 64 & sleep on my OWN, King Size Bed, beside Ol' Bills' BEND-A-BED I burrow under my OWN comforter & sleep 'til NOON, if I want to. IF I ever got cold, I'd go under the covers, with Ol' Bill & we have FART contests
Buster T. (Spoiled!)
"THE ASSISTANT GURU OF STUFF"
Old 01-19-2018, 07:16 AM   #16
ChicagoBob
ChicagoBob's Avatar
I recall, that after I installed pans about 25 years ago, one of the flanges at the oil pan edge broke after only a couple of weeks, leaving the pan edge to rub against the engine and make a horrendous graunching noise as the car moved. Turns out this was a service bulletin item. I recall that Ford's solution was to remove the offending flange and use only one oil pan bolt.
ChicagoBob is offline   Reply With Quote
Old 01-19-2018, 08:15 AM   #17
aermotor
I also recall something about removing the front flange, but for the life of me I can't find it now.
John
Old 01-19-2018, 09:06 AM   #18
JohnB15632
JohnB15632's Avatar
To Bill,
I was not laying on the cold floor directly, I had two pieces of carpet and a piece of cardboard. I am not so stupid as to lay directly on the concrete. Give me a break!
Even thought the temperature gauge read 55, when I was down under the car, I could still see my breath.
It is just plain cold!!!
Old 01-19-2018, 10:52 AM   #19
BILL WILLIAMSON
Originally Posted by JohnB15632 View Post
To Bill,
John, Dog here,
I'm so SORRY if I OFFENDED you, please forgive me.
Buster T.
Old 01-19-2018, 01:11 PM   #20
chap52
chap52's Avatar
The older I get (72 in Feb) the tougher it is to do the "floor jobs". Seems that once I get down there I forget why I am on the floor and upon remembering I lay there and list all the tools I didn't bring with me. Chap
