Old 12-30-2017, 03:41 PM   #1
burner31
burner31's Avatar
Default To cold to be in garage
It's a cool 15 degrees out there today, and inside the garage is even colder.
I drained the water out of the car today, changing out hoses so had to be done anyways.
Think I'll stay inside the warm house the rest of today.
Keith
Shawnee OK
'31 SW 160-B
Old 12-30-2017, 03:55 PM   #2
Pinesdune
Pinesdune's Avatar
Default Re: To cold to be in garage
Could be worse....
Just a screen shot of my phone this morning from our local weather service
Pinesdune is offline   Reply With Quote
Old 12-30-2017, 04:08 PM   #3
Davew
Davew's Avatar
-24 here this morning. -20 now. Good day to review the service bulletin book.
Davew is offline   Reply With Quote
Old 12-30-2017, 04:12 PM   #4
Crankster
Crankster's Avatar
-36° ?
How much is that in American?
Crankster is offline   Reply With Quote
Old 12-30-2017, 04:14 PM   #5
quickchange
quickchange's Avatar
Hell no its 22c here , too hot , & with 12 hours till new year might need too crack a cold one , Happy new year too all, your summer is coming , well later on in the year , ? Time too jump in the pool & cool off , see you in Sparks in June ,
quickchange is offline   Reply With Quote
Old 12-30-2017, 04:23 PM   #6
pooch
pooch's Avatar
I have to think for a bit when Fahrenheit is quoted.
But when it is that cold -36, it does not matter much..... -40 F is the same as -40 C.
And all I know is, the coldest I have ever been in is -8 C and that was cold enough.
You guys can keep your brass monkey temps and your tornadoes and earthquakes , I will have my fine sunny beach in OZ any day.
pooch is offline   Reply With Quote
Old 12-30-2017, 05:05 PM   #7
Curtis in MA
I took the front spindles and king pins off and brought them in.
It was a high of 14F here.
Curtis in MA is offline   Reply With Quote
Old 12-30-2017, 05:23 PM   #8
kenparker
kenparker's Avatar
have the 80,000 btu heater operatin wide open and it is a comfortable 68 degrees in my shop - only 31 outside. yeh guys, i am spoiled.
Had to build a "pipe the exhaust to the outside system" today. Running and engine in a closed shop is a no-no. Had two carburetors to get tested for some club fellows.
"twas a very good day". ken
kenparker is offline   Reply With Quote
Old 12-30-2017, 06:41 PM   #9
Synchro909
Synchro909's Avatar
I'll second that! Here in Melbourne, it is 20 (68F) degrees outside right now and climbing. Fine and sunny. Heading for 25 (77F) degrees. MAGNIFICENT!
Old 12-30-2017, 08:30 PM   #10
glenn in camino
glenn in camino's Avatar
I have radiant heat under the floor in my garage. It's always 65-70 F. See Radiant Tech.com.
Old 12-30-2017, 08:36 PM   #11
Pinesdune
Pinesdune's Avatar
I wish I had that in my shop, supposed to be fantastic heat, floors always warm...
Old 12-30-2017, 08:42 PM   #12
JRHASZARD
JRHASZARD's Avatar
I just pretend it's 1967 and I am at Ft. Rucker in training. I remember the warm feeling I got when I left Alabama. Works every time.
JRHASZARD is offline   Reply With Quote
Old 12-30-2017, 08:46 PM   #13
Clem Clement
Clem Clement's Avatar
Back in the day, I rolled down the runway in Eielson AFB at -56F or rather I tried. the engine run up air blast froze the wheel bearing's grease. We were parked on compact snow. We slid back to the hanger and hit the bearings with 3 Herman Nelsons. Then made a rolling Take Off. throttle hit max MP at 50% of handle travel.
Happy new Year all.
Old 12-30-2017, 09:27 PM   #14
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I've had a Dayton, 220 Volt Space Heater, for 8 years, NEVER have plugged it in.
Bill Guiltyassin
"THE ASSISTANT GURU OF STUFF"
Old 12-30-2017, 09:37 PM   #15
denis4x4
denis4x4's Avatar
You guys are all telling lies! Global warming is here according to those in the know and we should be thankful for wind power and solar!
BTW, I’m in SoCal and it was 70 at the beach.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 12-30-2017, 09:48 PM   #16
JRHASZARD
JRHASZARD's Avatar
Back in the day at Eilson, we took a Herman Nelson inside with us so we could use it to heat the other Herman Nelsons to get them started. Blew a few prop seals.
Old 12-30-2017, 10:53 PM   #17
holdover
in my area of VA it never gets quite as cold as some of the areas posted, but we have our share of 20F and lower days. When I built my garage I put 12" of insulation in the ceiling and 6" in the walls. I have a big electric wall heater next to my work bay and a propane heater that makes it warm enough to work in, but I look forward to those warmer days coming in about 3 months or so...
holdover is offline   Reply With Quote
Old 12-30-2017, 11:21 PM   #18
California Travieso
Send a message via Yahoo to California Travieso
Keep an eye out for the Great White Sharks, mate. And have a Happy and Prosperous New Year.
It was 81 degrees Fahrenheit here but no water.
David Serrano
California Travieso is offline   Reply With Quote
Old 12-30-2017, 11:42 PM   #19
Bill G
Bill G's Avatar
It warmed up here to about 43 degrees (F) today. I got out to the garage to do some tinkering. I didn't want to start any projects because it will turn cold again soon enough.
Old 12-30-2017, 11:49 PM   #20
Licensed to kill
Licensed to kill's Avatar
I'll take my chances with maybe getting frost bite rather than maybe getting a snake bite or spider bite from the plethora of venomous critters over there.
Licensed to kill is offline   Reply With Quote
