05-13-2013, 12:03 PM | #1 |
Change out my 34 - 4 dr ; Rear Spring
I will be changing out my 34 4 dr ; Rear Spring, is this a very big job ? what special tools will I need , also what year Early Ford will bolt in place of the original spring, thanks guys !
05-13-2013, 01:29 PM | #2 |
Re: Change out my 34 - 4 dr ; Rear Spring
Ford closely matched the springs to the specific body styles. You would be better off keeping the original spring. The spring is under tension even when the car is jacked up. I jack up the rear of the car and put stands under the frame. You can now put jacks under the shackles and come up on them untill a spot is found to have no load on the shackles. You can now remove the shackle links and remove the spring.
05-13-2013, 01:37 PM | #3 |
1933 is the only year spring that will interchange. Each body style generaly has different spring arrangement, that is, different number and arrangement of leaves in the spring. Why do you need to change the spring?
05-13-2013, 07:40 PM | #4 |
Why do you need to change the spring? x2
05-13-2013, 08:55 PM | #5 |
Guys ... the Spring seems to be weak and or missing some leaves, I put new rubber bumpers on the frame just above the axle and had to cut them down to give some clearance but it still bumps, I think the previous owner wanted a lower look, as the front spring has been changed out to a single thick one leaf spring, I have the original front spring and may change it out as well, as the left side wheel hits the steering arm from the steering box arm when I turn sharp to the left , thanks for any advice .. R..
05-14-2013, 03:52 AM | #6 |
You will need to borrow a Spring Spreader to effectively and safely remove the spring. This can be a scary operation as there is a lot of energy stored in the spring, but once the tension is off the shackles it is easier to remove them. Once the spring is out count the number of leaves, I'm not sure how many your year had but could be around 11 or 12. A Springmaker could make new leaves (or a whole new spring) and reset the curve. Also it might be a good idea to check the shockies while the spring is out. |
