Old 09-28-2019, 02:22 PM   #1
Joop
Joop's Avatar
Default Different Model A Venturi
Found this at a Swap Meet today.
Same as Zenith but with brass insert.
Does not look home made.
What is it for.
Thanks
Joop is offline   Reply With Quote
Old 09-28-2019, 02:53 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Different Model A Venturi
Looks like some sort of aftermarket venturi. Put it in a Zenith carburetor and see if it runs.
Mike Peters is offline   Reply With Quote
Old 09-28-2019, 03:33 PM   #3
Benson
Benson's Avatar
since venturi is smaller maybe it is for a British engine ...
Although Henry would have used all pot metal unless there was a manufacturing problem which required brass for the smaller opening.
Brass was expensive
Old 09-28-2019, 04:17 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
If the inside diameter of the venturi is smaller it will restrict power .
Old 09-28-2019, 05:51 PM   #5
Joop
Joop's Avatar
Added some pictures
Old 09-29-2019, 06:00 PM   #6
Joop
Joop's Avatar
Any foreigh help on this
Old 09-29-2019, 06:03 PM   #7
daveymc29
daveymc29's Avatar
Si, No es Ford!
daveymc29 is offline   Reply With Quote
Old 09-29-2019, 10:17 PM   #8
Brad in Germany
Brad in Germany's Avatar
The carburetor for the AF engines did have a smaller orifice venturi (and smaller jet orifices as well).
Here is an original, April 1931, document from Zenith, France indicating the size of the AF single venturi. See the blue arrow indicating that the venturi of the carburetor for the AF engine is "18" compared to the venturi for an A and AA engine is "21.5" (look under the "Diff" column):
"Diff" = Diffuseur, the french word for venturi
So based on the measurements that you show of your mystery venturi, it seems like it is not a venturi for a Model AF engine.
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 09-30-2019, 07:16 AM   #9
Joop
Joop's Avatar
Thanks for posting that info Brad
Old 09-30-2019, 10:03 AM   #10
johnbuckley
johnbuckley's Avatar
Yes I concur with Brad the smaller engine was 18mm dia venturi ( approx 0.7 inch). Suspect that the venturi in the OP is someone's experimentation.
Old 09-30-2019, 02:56 PM   #11
SAJ
SAJ's Avatar
Originally Posted by daveymc29 View Post
Si, No es Ford!
Good one Davey!
SAJ is offline   Reply With Quote
