09-05-2018, 07:45 AM | #1 |
spring perch mounts for quick change banjo with torque tube or open drive
City:
Ashland
State:
Va
Price:
150.00
Here is a spring perch that will bolt/weld on your banjo quick change rear that rotates the banjo to the rear 5 degrees.
These brackets compensate for the rear axle assembly to rotate towards the rear, allowing the torque tube and driveshaft to align with the transmission, and can be used if your running an open drive shaft. 150.00 which includes shipping to the lower 48 Feel free to call with any questions or to place an order Havlir House of Fabrication Dave Havlir 804-245-1959 Here is a link to the straight up spring perches for standard banjo rear https://www.jalopyjournal.com/forum/...rsion.1067209/ Spring perches are available as 2" wide for Model T spring or 2 1/4" for Model A spring The first pic shows the straight up version on the left and the 5 degree version on right. |
09-09-2018, 10:27 PM | #2 |
Re: spring perch mounts for quick change banjo with torque tube or open drive
