08-08-2011, 04:03 PM | #21 |
Re: vinegar somor
I have photos of the slop that I drained out plus the inside of the rad if someone would post them for me.
08-26-2011, 09:13 PM | #22 |
Re: vinegar somor
After cleanup, I find a fine block crack behind the starter. I assume the vinegar opened an old crack. It doesn't appear to weap much. Should I use radiator stop leak? Baar's block leak bottle sez to disconnect the heater etc. Can I use radiator sto leak first app and see what happens. Or did the vinegar clean the crack enough for it to rust closed?
clem |
08-27-2011, 08:25 AM | #23 |
Tales from the dark side
Tales from the dark side , Did the vinegar thing at 5% for a week or about 800 miles of driving with my summer beater - 33 5w . Yeah a lot of ugly-smelly crap came out and after flushing and neutralizing with baking soda I now have leaks in 5 places on the motor . Both mounts,1 waterpump , the other waterpump to head gasket & last but not least one of the expansion plugs on the pan rail . The last is by far the most troubling as it is leaking outside AND INSIDE so it is letting a little water in the oil . This car had been sitting since the early 50's and was brought back to life last spring . I had the heads off and they are aluminum and they don't leak . It'll be some time B4 I do this to myself again . Car is parked till I can pull the pan and fix leaks . Kinda crappy to do something to help it and it takes it out of service . David J
08-27-2011, 09:08 AM | #24 | |
Re: Tales from the dark side
08-27-2011, 01:10 PM | #25 |
Re: vinegar somor
David J. ...................
MAN ! You'd kick if someone cut off your legs ! ... LOL That vinegar did not make your car leak. It just showed you were you had leaks, that were held together with rust, sand, grease or decades old stop-leak. Like jdl said, those leaks would have showed up, later, anyway. You can, probably, get back in service with some fresh stop-leak. MIKE |
08-28-2011, 12:10 AM | #26 |
Re: vinegar somor
08-28-2011, 11:06 AM | #27 | |
Re: vinegar somor
I'm really sorry that you had to take your '33 off the road. I'm really happy that I did not p___ you off with my comments. But, you got to admit that vinegar works. It cleans out the crud. Even the crud that is making your block waterproof. I don't think that you are the first that this has happened to. My '35's radiator leaked after doing the vinegar thing. I put in some new stop-leak and it hasn't leaked since. Good luck, MIKE |
08-30-2011, 12:00 PM | #28 |
Re: vinegar somor
I just filled my 53 8ba thats sitting in my garage. I will be flushing it thursday and cant wait. I will post pics when i do it. Hopefully some dead horses dont come out.
