Old 12-02-2019, 05:50 PM   #1
Mr. Will
Mr. Will's Avatar
Default 1933-34 Steering Column Tube
Can anyone tell me what the length on a 33-34 steering column tube is? Any help would be appreciated.
Thanks Dan
Mr. Will is offline   Reply With Quote
Old 12-02-2019, 06:13 PM   #2
Terry,OH
Terry,OH's Avatar
Default Re: 1933-34 Steering Column Tube
34 is 36-1/2"
Old 12-02-2019, 06:58 PM   #3
Mr. Will
Mr. Will's Avatar
Thanks for the information.
Old 12-02-2019, 07:57 PM   #4
David J
David J's Avatar
I'll look for the dimension but early 33's are not the same length as 34 . Light switch rod and steering shaft are also different than 34 .
David J is offline   Reply With Quote
Old 12-02-2019, 09:37 PM   #5
Mr. Will
Mr. Will's Avatar
Any information would be appreciated. I do have a 33.
Old 12-02-2019, 10:02 PM   #6
koates
The first 10,000 approx. 1933 Fords had a steering shaft 41 3/4"" long and all other 33-34 Fords are 42"long. Not sure on the tubes. Apparently those early cars the steering wheel rim was too close to the top of the metal dash panel and the fingers of your hand could rub on the dash. I read that some years ago somewhere. My cars are 34s and I have thin fingers so never a problem, Regards, Kevin.
koates is offline   Reply With Quote
Old 12-02-2019, 10:14 PM   #7
cas3
this may be what david j has in mind. it came with my canadian 34 coupe, which has a lot of 33 features on it. its the black one on left. note there is a flat flange at the top, and not the more common flare like the brown one next to it, which is a few years newer, not sure. it measures 36 1/4. not much difference but it was enough that when installed the slit at the bottom was out farther than the boss on the steering box when the tube was up next the the steering wheel so dirt and water could get in. in my steering box rebuild of making a good box from various parts i must have ended up with the slightly longer 34 shaft. hope this helps. david j, how did i do? get it right?
Old 12-02-2019, 10:15 PM   #8
Mr. Will
Mr. Will's Avatar
My car has a Vegas box in it now with a aftermarket tube and 40 wheel. I'm switching that setup out to a F100 box and want to run original tube with 39 Deluxe wheel and working light switch. I don't have a tube but had measured a freinds 34 in his car and knew it had to be 36-1/2" -37 but wanted to verify that.
If anyone has a 36-1/2" tube they would be willing to part with I would be intrested.
Thanks Dan
Old 12-02-2019, 10:21 PM   #9
cas3
if you dont care about the lock feature then you just use 1 1/2" tube. leave it straight, or make the flare like on the brown tube in my photo
Old 12-02-2019, 10:35 PM   #10
Mr. Will
Mr. Will's Avatar
I'm using the original drop with lock so, would like to find an original tube.
Old 12-03-2019, 07:17 AM   #11
Terry,OH
Terry,OH's Avatar
you can shorten a longer tube from another year. You may have to modify the lock bolt holes slightly. I used a 37 outer column.
Old 12-03-2019, 09:49 AM   #12
Jim in Wisconsin
I have an original 33 2 door sedan and the steering tube is 36 3/4 long.
Jim S.
Jim in Wisconsin is offline   Reply With Quote
Old 12-03-2019, 10:13 AM   #13
Mr. Will
Mr. Will's Avatar
Yes, I have considered that as well as making a whole new tube which may be easier.
The 39 tube I have has the lock location at 8-1/4" while the 34 36-1/2" tube locates the lock at 7" so it's more then just shortening the tube which is doable but finding a original would be nice.
Old 12-03-2019, 02:34 PM   #14
FlatheadTed
FlatheadTed's Avatar
What about a 32 tube ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 12-03-2019, 02:49 PM   #15
Mr. Will
Mr. Will's Avatar
The 32 tube does not have the flare at the top.
Old 12-03-2019, 03:09 PM   #16
FlatheadTed
You could make the flare by holding it over the edge ( maybe 1/4 to 1/2 )of a wood bench and tapping it around with a ball peen hammer ,not sure what the measurement is to the lock maybe 7"
Old 12-03-2019, 03:14 PM   #17
Mr. Will
Mr. Will's Avatar
Yes, 32 is 7" to the lock. Don't want to use a 32 tube.
Old 12-03-2019, 03:31 PM   #18
FlatheadTed
A Exhaust shop as Cas says, could flare it ,then just drill it for the lock ,
Old 12-03-2019, 06:05 PM   #19
TJ
TJ's Avatar
An exhaust shop is your best bet. Had a tube made years ago for a '36 and they can flare the top to meet your specs.
Old 12-03-2019, 10:32 PM   #20
Mr. Will
Mr. Will's Avatar
That is definitely a option and may prove to be the best way to address the issue but in the meanwhile I'll look for a original 36-1/2" tube.
