11-14-2017, 09:12 PM | #1 |
Oil change?
Is it 5 quarts of oil when you have an oil filter?
11-14-2017, 09:22 PM | #2 |
Re: Oil change?
Six on initial fill. Or just add the filter capacity.
11-14-2017, 09:24 PM | #3 |
Re: Oil change?
Drain oil, fill the first 4 run the car/prime and top up as needed.
11-15-2017, 12:27 AM | #4 |
Re: Oil change?
yup - same goes for anything with a dipstick. its never exactly 4 qts or whatever
1929 Model AA - Need long splash aprons! |
11-15-2017, 11:09 AM | #5 |
Re: Oil change?
Using an oil filter and a K&N air filter will keep your oil clean for several months.
11-15-2017, 11:22 AM | #6 |
Re: Oil change?
11-15-2017, 02:22 PM | #7 |
Re: Oil change?
11-15-2017, 07:31 PM | #8 |
Re: Oil change?
If you just drain the oil, the old oil will stay in the dipper tray so you still only need 4 qts. The dipper tray does not drain unless you have one with holes or have drilled holes.
11-15-2017, 08:07 PM | #9 |
Re: Oil change?
with the filter, it took 5 1/2 Qts.
11-15-2017, 09:01 PM | #10 |
Re: Oil change?
Adding 5 1/2 QTs on a refill seems about 1 too many, maybe after the pan is off and cleaned.
11-15-2017, 10:07 PM | #11 |
Re: Oil change?
Thread Tools | |
Display Modes | |
