Old 03-17-2012, 08:10 PM   #1
Bondolero
Bondolero's Avatar
Default 33-34 pickup seat question
My 34 truck cab has a nice back spring but has the individual biscuit cushions on the bottom that are separate. Is there a one piece bottom cushion that will fit well on the gas tank ?
thanks for any info.
Larry
Bondolero is offline   Reply With Quote
Old 03-18-2012, 02:41 AM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: 33-34 pickup seat question
I think you could use the small truck springs. The split cushions are large truck type. Macs in NY carry the full ones ..
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 03-18-2012, 04:37 AM   #3
Kerk
Smile Re: 33-34 pickup seat question
The split seat bottom is allow for filling the gas rank that was the seat base on at least some 32 pick ups.
Kerk is offline   Reply With Quote
Old 03-18-2012, 06:23 AM   #4
31chevy
31chevy's Avatar
My 34 pickup has the gas tank at the rear of the bed, not under the seat.
Gary.
31chevy is offline   Reply With Quote
Old 03-18-2012, 08:30 AM   #5
jimTN
My 34 pu has the split cushions and I believe they are original, have seen several others the same way.
Old 03-18-2012, 08:50 AM   #6
G.M.
All of the 34 P/Us I have seen had a 1 piece seat with the gas tank behind the rear cross member. My 32 woody has the tank under the seat. Check the frame serial number to see what year the frame is. It is on the top off the left front frame rail and can be anywhere from the firewall to the front cross member. G.M.
www.fordcollector.com
Old 03-18-2012, 10:23 AM   #7
Reds34
As far as I know the pickups had the gas tanks under the bed while the big trucks had the gas tank under the seat. So the pickups would've had a one piece seat while the big trucks would've had the split seat.
Red
Reds34 is offline   Reply With Quote
Old 03-18-2012, 10:46 AM   #8
Bondolero
Bondolero's Avatar
It is a big truck cab and has the gas tank located under the seat. I have moved the tank to the rear frame (I am using a car frame). I have cut the top out of the gas tank to use as a seat riser inside the cab like the regular 1/2 ton. I am asking if the one piece seat springs are available or if a 34-35 bottom cushion will work. I do not have access to one to measure it. I would purchase a 1/2 ton seat riser and bottom cushion if available ?
thanks for all the replies, I appreciate the help.
Also although I havn't figured out how to change my signature, I have found a nice set of mercury hubcaps thanks to the generosity of one of the Ford Barn members.
Old 03-18-2012, 11:04 AM   #9
Chris
Chris's Avatar
The 33-34 solid bottom spring should work fine. Yours sits on the actual gas tank, or is there a seat riser around the tank as well? Heres a picture of my pickup...
Thee Inland Emperors
Chris is offline   Reply With Quote
Old 03-18-2012, 11:07 AM   #10
L head fan
One piece bottom seat cushion for a '34 pickup should work. Check with LeBaron Bonney, Macs, or other suppliers and I'm sure you'll find the seat spring or complete bottom upholstered cushion.
L head fan is offline   Reply With Quote
Old 03-18-2012, 11:09 AM   #11
L head fan
Sorry Chris...I type S L O W !
Old 03-18-2012, 11:39 AM   #12
GeoMaher
My 1934 Ford P/U has the fuel tank between the frame members at the rear also. The P/U fuel tank is the original one that came with the P/U when is was bought brand new at the Michigan, North Dakota dealership. I bought the P/U from Vern Hanesalo who is the original owner according to the paperwork that came with the P/U. The fuel tank is between the frame rails at the rear of the vehicle.
GeoMaher is offline   Reply With Quote
Old 03-18-2012, 02:20 PM   #13
Jack 34pu
Jack 34pu's Avatar
Get a new one piece and it will fit the gas tank - and more comfortable.
Jack 34pu is offline   Reply With Quote
Old 03-21-2012, 06:49 PM   #14
rickmass
my 2 cents my gas tank is in the rear of the truck on my 34.Rick
rickmass is offline   Reply With Quote
Old 03-22-2012, 10:05 PM   #15
Straightpipes
Straightpipes's Avatar
Gas tank location: 32 Pickup is under the seat
33-34 Pickup is behind the rear crossmember
( same as the car)
32-34 Big truck is under the seat
the 34 cab in my avatar came from a dump truck. I use the original tank as a seat stand.
Straightpipes is offline   Reply With Quote
Old 03-23-2012, 06:04 AM   #16
FlatheadTed
ILL 2nd that .
( same as the car)
Old 03-23-2012, 09:04 PM   #17
Straightpipes
I see some of the hot rodders cut the tank out for a storage bin. Have not done that as I hate to ruin a good tank, but my seat is hinged at the front.
Old 03-24-2012, 07:54 AM   #18
31chevy
31chevy's Avatar
Here are pic's of gas tank & seat in my 34 pickup, hope this helps.
Gary.
Old 03-28-2012, 09:57 AM   #19
rickmass
31 chevy what is that swith under the seat for.Rick
Old 03-28-2012, 10:40 AM   #20
al's28/33
al's28/33's Avatar
Looks like a battery disconnect switch to me, good place to put it. Nice job on your restoration.
