Old 01-13-2020, 12:35 PM   #21
JSeery
JSeery's Avatar
Default Re: Rebuilt motor start up
Sorry to keep on your case Gary, but there is more repair required!
"After it's all broken in, remove the "grub" screw and plumb in the filter!"
"remove" should be "install".
Old 01-13-2020, 12:59 PM   #22
GOSFAST
GOSFAST's Avatar
Hi J, quite alright, we don't need wrong info up here, especially from me!
Thanks, Gary in N.Y.
P.S. I have no issues ever being corrected!
GOSFAST is offline   Reply With Quote
Old 01-13-2020, 04:00 PM   #23
jrvariel48
jrvariel48's Avatar
Sounds good Gary, but I have an aluminum bellhousing and a steel adapter to make the 8BA fit the T5 so I'm not sure how to make that work.
jrvariel48 is offline   Reply With Quote
Old 01-13-2020, 05:32 PM   #24
Ziggster
Originally Posted by Brian View Post
My opinion....people say that with new cam and lifters, the motor needs to be run at 2000 RPM for 20 minutes in order to run those components in.
New rings need to be run under load to get them bedded in correctly.
Therefore, achieve both jobs at once; get vehicle running, then DRIVE it.
This is essentially what my machinist told me. He said the reason behind running the engine at higher revs was to ensure there was enough oil getting to the lifters as they just rely on oil "splash" and not direct oil lubrication.
Ziggster is offline   Reply With Quote
