Old 04-14-2019, 09:11 PM   #1
1930deluxe
Default Water pump Update
What may have caused this pump to crack? See Photo
https://imgur.com/tjfllV4
1930deluxe is offline   Reply With Quote
Old 04-14-2019, 09:18 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Water pump Update
Old age!
www.whidbeymodelaclub.com
Old 04-14-2019, 09:21 PM   #3
joncrane
Why did it crack? … 80 years old, worn bearing with vibration, tight fan belt poor original casting, dropped while being removed or blasted. I had one in good shape and sand blasted getting ready to rebuild. When we added the new bearing it cracked the housing. Funny thing is the housing did not crack until a few days after we pressed in the bearing.
joncrane is offline   Reply With Quote
Old 04-15-2019, 03:24 PM   #4
jwilliams81
jwilliams81's Avatar
Someone tightening the nut too tight?
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 04-15-2019, 07:50 PM   #5
F.M.
What Nut ??
F.M. is offline   Reply With Quote
Old 04-16-2019, 07:58 AM   #6
jwilliams81
Originally Posted by F.M. View Post
What Nut ??
The nuts used to bolt the water pump to the head.
https://www.snydersantiqueauto.com/P...l-a/water-pump
Cincinnati, Ohio
Old 04-16-2019, 10:51 PM   #7
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Possibly from driving out,or in the front bushing assembly, in an incorrect manner.
Old 04-17-2019, 10:25 AM   #8
katy
katy's Avatar
I would suspect that the press fit was just a tad too tight.
Old 04-17-2019, 11:02 AM   #9
1930deluxe
Katy was right the new bushing was too large to be installed in the housing. The housing measurement is 1.016 and the bushing measured 1.021. Five thousandth puts too much force on the housing without cracking it. It is a good lesson to all that quality control just is not present in today's market. We no longer can take for granted that since it is new it will fit properly.
Old 04-17-2019, 11:26 AM   #10
Benson
Benson's Avatar
too much drama
