05-08-2017, 05:30 PM | #1 |
Stromberg 97 Choke Screw Thread...
Does anyone know what thread the choke fulcrum screw is?
This is the large headed shouldered bolt that the choke linkage pivots on. Mine has stripped I the carb top and I'd like to helicoil it. Thanks. |
05-08-2017, 05:52 PM | #2 |
Re: Stromberg 97 Choke Screw Thread...
12-28
Charlie ny |
05-08-2017, 06:20 PM | #3 |
UNF?
I thought all the fixings were UNC? |
05-08-2017, 06:25 PM | #4 |
12-28 is SAE, fine thread. 12-24 is USS, course,
05-08-2017, 07:06 PM | #5 |
I searched everywhere for helicoils for these damn things.
Finally ordered them from a company in France. www.threadtoolsupply.com Not cheap.
RIP Tyler... My Son, Helper & Best Friend. Feb '78 to Father's Day '10. www.97-express.com ~ [email protected] |
05-08-2017, 07:24 PM | #6 |
Phil NZ. |
05-08-2017, 08:54 PM | #7 |
I had the same issue and used this Loctite product and was happy with the result.
http://na.henkel-adhesives.com/produ...=8797876355073 |
05-09-2017, 05:57 AM | #8 |
Why not send your carburetor top ( air horn ) to Charlie NY. He has repaired many stripped holes in carb tops for me.
05-09-2017, 07:46 AM | #9 |
Enbloc,
Over time I've sort developed a Stromberg rescue service at the request of Nick, Max and others. For this repair I fixture the air horn and open up the stripped 12-28 to 5/16 -24 and thread in a brass bushing which I've already tapped a 12-28 thread into. This is a life time repair. Removal of power valves, idle tubes, 'j' tubes etc etc USUALLY are no problem. Charlie ny |
05-09-2017, 08:28 AM | #10 | |
Charlie is Da Man! |
05-09-2017, 05:34 PM | #11 |
Upwards of 30 otherwise roached 97's saved by that Charlie guy!
05-09-2017, 06:00 PM | #12 | |
Thanks for all the help.
05-09-2017, 07:05 PM | #13 |
Enbloc,
I will bet you know someone with a lathe and a steady hand at a drill press or mill (preferred) that can facilitate the repair described. "Don't never throw anything away", to quote a fellow Barner. Charlie |
