10-03-2014, 08:39 AM | #1 |
Horns, Screws and Lockwashers ???
Just trying to figure out stuff.
In the process of putting together a Stewart Warner horn. The screws holding the 3 parts together had lock washers on the one I took apart and the other did not have lock washers but I am pretty sure it had been apart. The other horns I have are Sparton. The one together has no lockwashers. I also noticed that the Sparton has smaller nuts then the SW nuts (same threads, just different OD). The reason I ask is the 4 split type lock washers I have are a thinner and slightly smaller OD then the new style I have laying around. I would need 2 more correct lockwashers. Before I go on a hunt for lockwashers I figure I best find out what is correct. Thanks! |
10-03-2014, 01:44 PM | #2 |
Re: Horns, Screws and Lockwashers ???
The horn information as to nut sizes and other details is referenced in the Restoration Guidelines & Judging Standards. Some of the parts you need are sold by A&L.
10-03-2014, 06:07 PM | #3 |
I agree...first check the Restoration/ Judging Standards manual, available from either national club.
Then give a call to A&L Parts Specialities to get what you need. |
10-03-2014, 07:05 PM | #4 |
Also remember that the lockwashers only came on the two bolts that hold the bracket to the horn. the other 4 bolts had no lockwashers.,
10-03-2014, 07:20 PM | #5 |
