Old 05-18-2019, 11:17 PM   #1
Russ/40
Russ/40's Avatar
Default Need dimension of bearing surface axle housing race
The title says it. Anyone that can help me with the housing race dimension or wear limit ?
40 ford
Russ/40 is offline   Reply With Quote
Old 05-19-2019, 11:38 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Need dimension of bearing surface axle housing race
Come on guys someone has the answer. How about a repair sleeve. Can I get an outside dimension?
Old 05-20-2019, 01:17 AM   #3
RobR'35
RobR'35's Avatar
I've read on here and wrote it down some time ago. Factory 2.061 to 2.063 max. additional wear allowed is minus 5 mils. I don't really get the mils part. I believe it means .005?
Not sure on the wear spec.completely.
I've measured on my car years ago with replaceable sleeves installed before I owned the car. Areas where the bearing didn't ride measured in the spec. I wrote above.
RobR'35 is offline   Reply With Quote
Old 05-20-2019, 09:57 AM   #4
Russ/40
Russ/40's Avatar
Thank YOU sir!
Old 05-20-2019, 01:15 PM   #5
RobR'35
RobR'35's Avatar
Your welcome.
