09-22-2013, 05:09 PM | #1 |
curious what you think
I've been thinking of using a 3 bolt to four bolt adapter to enable the use of a later model 2 barrel carb like a rochester 2CG on stock aluminum intake. Any one thoughts or recommendations.
09-22-2013, 05:17 PM | #2 |
Re: curious what you think
You will have to match the intake ports to the base Venturi of the 2GC. Not a big deal, but necessary for optimal performance.
09-24-2013, 09:26 AM | #3 |
The intake manifold has two round holes matching the 97 carb, the available adapters all seem to be just oval without the center division. Do you suggest removing the area between the two holes in the manifold? The 2CG would up the cfm to about 350. Anyone with experience with adapters like these?
09-24-2013, 10:54 AM | #4 |
Nothing against the Rochester, but what about the new Edlebrock 94s? It should go with no mods.
09-24-2013, 12:30 PM | #5 | |
09-24-2013, 03:29 PM | #6 |
As a permanent installation, I converted a Mercury intake and blended the ports as suggested by Russ/40. I'm well satisfied with the results. FWIW
Henry |
09-24-2013, 03:40 PM | #7 |
I also converted to a Mercury manifold with a 2GC. Runs good in the driveway waiting for tags to gitur on the road. Zeke
Only problem with retirement is never a day off |
09-24-2013, 04:28 PM | #8 |
I didn't like the Speedway adapter because of the open plenum it creates. I got this kind instead, but want to add an aluminum plate under it to taper gracefully into the manifold (which I will somewhat open up). It does require drilling and tapping a hole pretty accurately on the top of the manifold, not a huge thing. It costs $55, which I think is excessive, but what can you do?
'52 F-1, EAB flathead |
09-24-2013, 05:32 PM | #9 |
I'm running a 2g on a Merc manifold on mine, love it.....won't ever go back.
09-24-2013, 06:06 PM | #10 |
I have two cars running with 4 bolt aluminum manifolds and Rochester 2g carbs. I found both to run a bit stronger than 94's. I got my manifolds from Bill Boomer in Canada. They polish up nice.
Pete PM me if you want his e-mail |
