09-21-2013, 04:22 PM | #1 |
Looking for a compression fitting
Decided to run nice looking 5/16" copper fuel lines between the pair of Stromberg 97"s and the mechanical fuel pump. Got the lines formed but ... I also want to do compression fittings instead of flared ends for the copper lines.
Searched high and low and can't find a fitting w/ a 5/16" compression fitting on one end and a male 3/8" SAE 20 threads/inch on the other end. The 3/8" SAE fitting is what is on the fuel inlet of the Strombergs. I can find npt but thats 18 threads per inch. Need the SAE 20 threads/inch male end. Anybody know of such a fitting? |
09-21-2013, 04:38 PM | #2 |
Re: Looking for a compression fitting
Is this what you are looking for? http://www.thehotrodcompany.com/shop...oduct_id=9081K
09-21-2013, 04:46 PM | #3 |
Try Edelmann fittings. My Carquest guy carries them. I would think 1/4" would work fine. JMO
http://www.plews-edelmann.com/search...h=AND&F_Sort=2 http://www.plews-edelmann.com/compression-fittings/ John |
09-21-2013, 06:12 PM | #4 |
First of all, your looking for the wrong thing. The inlet size is 1/2"-20. I can supply you with the fittings. Give me a holler.
www.dickshotrodcarbs.com |
09-21-2013, 06:24 PM | #5 |
Like John said all you need is 1/4" line,NO advantage to using 5/16". Fittings are availible. ken ct.
09-21-2013, 06:29 PM | #6 |
09-21-2013, 06:42 PM | #7 |
09-21-2013, 06:45 PM | #8 |
"Illegle" (sp.). Now where in the world did you hear that? Looks like we are all going to jail. LOL
John |
09-21-2013, 06:46 PM | #9 |
09-21-2013, 06:48 PM | #10 |
Thought I heard that if ya read it on the internet, it must be TRUE! DD
09-21-2013, 06:49 PM | #11 |
09-21-2013, 07:57 PM | #12 |
If I was going to use copper for fuel lines,which I wouldn't, I would much rather use flared fittings over compression fiitings. JMO. To each his own.
09-21-2013, 08:04 PM | #13 |
I liked to use the cad plated brake lines. I use the brake line nut and use a copper compression ferrel. I have done this since 1960 on all my carb lines.
09-21-2013, 10:49 PM | #14 |
LOL im old and not very literate, but show me one car that has a copper fuel line, all fuel lines are steel from the tank to the carb, take any car to have it saftey inspected and it wont pass using copper fuel lines
09-21-2013, 11:10 PM | #15 | |
You must not get out much. Copper fuel lines have been used since the 40's and are still used quite frequently today. And yes, they are legal.
www.dickshotrodcarbs.com Last edited by Dick's Hot Rod Place; 09-22-2013 at 11:16 AM. |
09-22-2013, 03:44 AM | #16 |
I've always been taught copper is fine, but put a twist in a long run to allow for expansion and clip pipe properly to stop it vibrating, as it work hardens then cracks.
09-22-2013, 04:35 AM | #17 |
I can only reiterate what has been said before. Use 1/4". Copper or steel, it all works. You can buy a 1/4" compression tee fitting to split the feed from one carb to two. 1/4" pipe will flow more than enough fuel for a flathead.
Mart. |
09-22-2013, 09:04 AM | #18 |
5/16" OD= 1/4" ID. Which measurement is being referenced when talking about line size
09-22-2013, 09:45 AM | #19 |
09-22-2013, 01:20 PM | #20 |
Most of the old stuff had copper plated steel. The copper plating was excellent to prevent rapid corrosion. This is what FoMoCo used back in the day. Copper fatigues faster than steel under vibration stresses. It will still last a long time but it isn't used at all in aviation for the fatigue factor. 5052 aluminum tube and stainless steel tube are the common types used there.
Copper tubing generally always has some service loops turned into it to absorb vibrations a bit better and lessen it's chances of fracturing as Tom Walker previously mentioned. |
Thread Tools | |
Display Modes | |
