Old 09-05-2019, 02:02 PM   #1
Rayfry
Default Transmission Leaking
Need to pull the trans on my 1949 ford coupe. Is there an access door in the front floor trans. hump area. Carpets are glued down and don't want to rip them up for no reason. I know the trucks had a trans. door but not sure about the cars.
Rayfry is offline   Reply With Quote
Old 09-05-2019, 05:57 PM   #2
Gene1949
Gene1949's Avatar
Default Re: Transmission Leaking
Don't think so. Mine doesn't have one.
Gene1949 is offline   Reply With Quote
Old 09-06-2019, 07:25 AM   #3
38coop
Yes, there is a cover over the transmission. You have to take the carpet out and remove some bolts and the cover comes off. Makes it easier to work on.
38coop is offline   Reply With Quote
Old 09-06-2019, 09:11 AM   #4
tubman
tubman's Avatar
Are you sure? The earlier cars had the removable transmission cover, but my '51, like Gene's, doesn't. Just curious. what is the year and model of car are you referring to?
Old 09-06-2019, 12:55 PM   #5
drolston
drolston's Avatar
For sure your transmission comes out and in from below. You can get to all of the bolts from there. I have done it on a creeper with the car on jack stands, but a lift and a transmission support jack makes it a lot easier.
Old 09-06-2019, 01:21 PM   #6
JT FORD
JT FORD's Avatar
The only door is under the driver floor mat, its for the master cylinder for the fluid.
JT FORD is offline   Reply With Quote
Old 09-07-2019, 07:21 AM   #7
38coop
I thought he was talking about the cover on the transmission hump. I have the one on my 49 off now while i am working on it.
Old 09-07-2019, 07:38 AM   #8
tubman
tubman's Avatar
Do you have a car or truck? If it's a car, I'd like to see a picture of it.
Old 09-07-2019, 07:55 AM   #9
38coop
I can take a picture with my phone, but not able to post it. Anyone i can Email it to. Might take a while as i have to push it out of the garage to get a good picture.
Old 09-07-2019, 08:08 AM   #10
tubman
tubman's Avatar
I don't need to see it that badly. I'll take your word for it. I was just curious why some have it but most don't.
Old 09-07-2019, 08:13 AM   #11
JSeery
JSeery's Avatar
I can post a photo for you if you like, email it to me. [email protected]
Old 09-07-2019, 09:08 AM   #12
38coop
JSeery. I tried to send some pictures but they said ymail is not availlable.
Old 09-07-2019, 09:34 AM   #13
Bill S
My 50 Ford car has a cover over the trans. Need to lift the carpet. If you lift the carpet slow by working a scraper between the carpet and floor it can be done. Be careful and you my not damage the carpet. Than you can glue it down again. You may have some type of pad under the carpet that you may have to deal with.
Bill S is offline   Reply With Quote
Old 09-07-2019, 10:07 AM   #14
tubman
tubman's Avatar
Carpet? Glued down? Every shoebox I have ever seen has a rubber floor mat in front. Is yours perhaps a Crestliner? How would you check the brake fluid if it were glued down?
Old 09-08-2019, 07:22 AM   #15
38coop
Tubman,i tried to send you a picture but it did not work out. I am technology challenged when it comes to computers and cell phones.
Old 09-08-2019, 07:57 AM   #16
Frank Miller
Frank Miller's Avatar
If you have a non overdrive it is easily done from below. I've done an overdrive on a convertible on which has the X member. Not easy. I made a fixture to hold it to the jack. I believe with the cross member out you can just slide it back then drop it.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 09-08-2019, 08:21 AM   #17
tubman
tubman's Avatar
"38coop" - Since you took the time to take a picture, I'd like to see it. Try to send it to my regular email : "[email protected]".
I am also "technology challenged". Verizon sends me weekly emails trying to get me to upgrade to a "Smart Phone", but I'm having none of it. The can have my "Flip Fone" when they "pry it from my cold, dead hands".
Old 09-08-2019, 09:55 AM   #18
tubman
tubman's Avatar
To the O/P. I just received a picture of the transmission access opening in "38coop"'s car. It sure looks factory to me. I guess you'll have to lift your carpet and see what you have. That being said, I don't think the transmission could come out that way; the opening is just too small, especially with an O/D transmission. Please keep us informed of how this works out for you.
Old 09-08-2019, 10:33 AM   #19
38coop
One of the benefits was adjusting the O.D. cable. Thanks for posting tubman.
Old 09-08-2019, 12:50 PM   #20
JSeery
JSeery's Avatar
Did you try it again? [email protected] I have never had anyone have an issue with it, let me know if you still have a problem.
