07-04-2019, 10:21 AM | #1 |
For Barners that like machining: Riser Block VIDEO.
I know some Barners like machining so I hope you don't mind me posting this.
I just posted up a video in a new format for me. This is just short snips from hours of videos cut together in quick succession to show how I made a riser block for my milling machine from a very large but not ideally shaped piece of steel. The action shots were distilled down to less than 6 minutes from hours of video. I hope you might like it, and any feedback is welcome, especially on whether the new format works for you. I'll also add my general channel address so you can check out all my offerings. Mart. Martsrods channel: https://www.youtube.com/channel/UCzc...Vro40j-vjjZShg Riser Block video: https://youtu.be/CJQFRPjD71M |
07-04-2019, 12:42 PM | #2 |
Re: For Barners that like machining: Riser Block VIDEO.
Nice project!!
Marvin Fagan 214-697-8430 |
07-04-2019, 01:25 PM | #3 |
Nice video. Thanks for sharing!
07-04-2019, 01:43 PM | #4 |
Excellent back yard Hot Rod machine work.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
07-04-2019, 05:11 PM | #5 |
