12-04-2018, 10:21 PM | #1 |
Rear Side Panel Board
Does the rear side panel board below the window on the 1930 tudor sedan go over or under the corner panel board. See photo
12-04-2018, 11:49 PM | #2 |
Re: Rear Side Panel Board
Did you get my e-mail ? You have some issues going on. There should be no notch cut out at the top of the sail panel. The sail panel gets upholstered and installed first then the quarter panel gets covered and installed so if anything it would fit "over" the sail panel. From what I'm seeing your quarter panel is not long enough and should taper from the top corner down to the seat riser. As it is I don't think your rear backrest will cover the corner.
12-05-2018, 10:03 AM | #3 |
No, I did not get your e-mail. I did not know how far the quarter panel needed to go back. I will install the seat back to get a better idea how long it needs to be. Plus I did not know which one was installed first. Thank you for your help.
12-05-2018, 10:59 AM | #4 |
Thread Tools | |
Display Modes | |
