01-29-2018, 11:28 PM | #1 |
Early '30's speedster, making and gathering parts
I'm getting a few things together for an Indy Ford-style speedster. The left and right dash panels are commercial brass door push panels I drilled for a GPS speedometer and Bosche gauges. The speedometer surround bezel I cut from 3/16'' aluminum plate to match the surplus F-4 aircraft gauge surrounds. A push-button start switch finishes off the driver panel. The right side I centered an aircraft- inspired rally clock. Both panels will be mounted with stainless hex bolts and washers. The steering wheel is a 18'' Kenworth wheel I brushed the chrome finish and ordered a Ford tie-tac and installed it onto the center hub of the wheel. lol My headlamps are '31 Ford. The body will be a boat-tail speedster style, steel on a tube framework. The chassis is a '98 Ranger, 4 cylinder and 5 speed. A '31 hood and '32 grill shell. A strange mix, but I think it will be fun.
Just Passin' Thru.....Slowly! |
01-30-2018, 02:30 PM | #2 | |
Re: Early '30's speedster, making and gathering parts
Let us see the metal work as you proceed on the cowl and tail section. Are you metal work skilled ? |
01-30-2018, 03:49 PM | #3 |
I have a little experience with metalwork. The steering wheel is not set in stone, but I do want a big one. We will see. lol I have an English wheel, a beader, a tubing bender plus all the body shop tools you could shake a stick at, having done it professionally for over 40 years. I'm always willing to learn, so holler if you have any good advice. Gary
01-31-2018, 01:04 AM | #4 | |
'good advice'...Yes, can you move all your stuff in next door and teach a 'youth' the metal trade ! I know an OLD guy who raced speeders back many decades ago. He is putting together another one from parts that he has had left over from the olden days. Awesome old guy, as he doesn't even have a driver license, but the 'fire still burns' in him for the need for speed ! I do speedster bench racing with him as often as we can. Smart guy about building A/B hot engines too. |
01-31-2018, 02:04 AM | #5 |
Hardtimes I worked on everyone elses cars for all those years, Since I've retired I'm doing them for ME! LOL Gary
Just Passin' Thru.....Slowly! Last edited by tinman080; 01-31-2018 at 02:24 AM. |
01-31-2018, 02:58 AM | #6 | |
Still like to see progress pictures , especially of tail and cowl build. Thanks. |
02-01-2018, 09:20 AM | #7 |
I like everything, except the steering wheel.
02-01-2018, 01:47 PM | #8 |
I agree. Too modern. A couple of years ago, I saw a guy at the National Roadster show who made reproductions of antique steering wheels. He probably has a website that you can find using Google.
I also saw a speedster on YouTube that had a Model T steering wheel. David Serrano |
02-01-2018, 04:30 PM | #9 |
I have a 4 spoke wooden wheel also. I would like to find a nice Bell wheel, but I want a big one (expensive). 14 or 15 inch won't do it for me. So until I find the ideal wheel, the 18'' modern wheel will do. All of my cars have had parts switched out or changed as circumstances allow during their builds. I have a 17'' T wheel on my REO. The other cars have tillers....lol Gary
02-01-2018, 07:24 PM | #10 |
If you don't have a lot of metal skills, a trick to make a boat tail is to use a hood from the 40's early 50's and split it down the middle. Then flip the outer edges to the middle. It will take some trimming of the edge but works. Once you have the shape you want then you weld the center up.
The Old Tinbasher. |
