06-08-2018, 04:00 PM | #1 |
august 1928 starter button-is this early model?
hello- my starter button is corroded- to replace it , do i just pull it straight out or unscrew it? when i go to reinsert a button does it go straight in or do insulator washers need to be realigned, in other words will washers shift when i remove button? thank u
06-08-2018, 06:21 PM | #2 |
Re: august 1928 starter button-is this early model?
disconnect battery, Screw out the starter rod,remove the four screws holding the starter switch on starter,remove wires first,take out.Repair or replace.
www.whidbeymodelaclub.com |
06-08-2018, 11:17 PM | #3 |
When did they switch from the square starter switch to the later style? Also didnt the early rods have a S bend in em and held by cotter pin or something?
I know the later style used a flat contact on the starter while the earlier style used a tapered wedge shape contact
1929 Model AA - Need long splash aprons! |
06-09-2018, 07:28 PM | #4 |
Not sure what you are asking about a "starter button" ???? If you are asking about the contact on the top of the starter that is not removed easy. However, you should be able to remove the starter switch and clean the contact in place with no problem.
From the beginning of production to Oct 28 the square switch was used with 2 variations which were associated with the rod. The 1st used through March of 28 had the offset rod. Beginning in April 28 the 2nd version was used this had a straight rod. Last edited by frank55a; 06-09-2018 at 07:57 PM. |
06-09-2018, 08:50 PM | #5 |
thanks for replies-- by starter button, i mean the round copper ,flat at top, 5/8" in diam , embedded in anterior of starter body which is probably connected to interior field coil. i always worry about trying to remove parts if i don't know how they are attached.
the button is badly pitted. |
06-10-2018, 10:11 AM | #6 |
06-10-2018, 12:37 PM | #7 |
thank you
