10-14-2018, 06:44 PM | #1 |
'55 Vic Hi Perf. 272
My newly acquired '55 Victoria has the stock 272 Special V-8 producing 182 hp.
Besides the 4 bbl carb, duals and 8.5:1 comp. ratio does anyone know if the cam was different? Also, how was the comp. ratio increased...via the combustion chambers or crowned pistons?
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
10-14-2018, 08:15 PM | #2 |
Re: '55 Vic Hi Perf. 272
The camshaft in the 182 HP 272 Y-Block is the same as the 272 2 barrel cam. The compression ratio of your engine was increased from 7.5:1 to 8.5: 1 by using different casting number cylinder heads that had slightly smaller combustion chambers.
Sal |
10-14-2018, 08:45 PM | #3 |
Beautiful car !!!!
10-14-2018, 11:58 PM | #4 |
Didn't see many of these back in the day. See fewer now.
10-15-2018, 03:14 AM | #5 |
Codes to compression ratios http://www.ford-y-block.com/cylinderheadchart.htm
10-15-2018, 04:28 AM | #6 | |
55 ECL-A - ECG-B 272 - 2 bbl - Int Valve - 1.78" CR 7.6 162HP 55 ECG-D 272 - 2 bbl - Int Valve - 1.78" CR 7.6 162HP 55 ECG-A - ECG-C 272 - 4 bbl - Int Valve - 1.78" CR 8.5 182HP (Combustion Chamber Volume -CC's- Not Shown On Chart)
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 10-15-2018 at 04:57 AM. |
10-15-2018, 08:06 AM | #7 |
Real nice like it a lot !
10-15-2018, 10:07 AM | #8 |
some 55 heads i cant remember which one had .035 shaved of to raise the comp,.
10-15-2018, 10:16 AM | #9 |
Thanks Guys...really helpful
