Old 08-09-2013, 04:40 PM   #1
Ross6860
Default 8BA Rods in a 59/59A
My car came with a donor motor. It's locked up and soaking for dis-assembly. Holes in three pistons on the same side of the motor.
I know it's a 59 block (cast bell-housing with the raised 59). I can see the rods are marked 8BA.
I'm pretty sure this is not stock. Anything to look out for?
It also has adjustable lifters and an aluminum cam gear. I know, just typical rebuild upgrades.
Nice thing is, the inside of the block, crank, rods and lifter valley look like no water or coolant got in. No signs of rust.
I plan on using this block, if it check out OK, as a base for a mild street motor for my '36.
Any suggestions from the learned masses?
Thanks in advance.
Never thought I would enjoy planning a whopping 175 hp (or less) build. Used to modern Fords (FEs and Clevelands).
I'm now hooked on flatheads...
Ross6860 is offline   Reply With Quote
