03-09-2019, 11:51 AM | #1 |
Update on starting problem
With 12V neg grd and a push start starter switch I suddenly had the car start only when I cranked it with the starter until it was rolling over rapidly then let off on the starter switch. In other words no spark while cranking. I received several suggestions concerning the rectification of the problem and yesterday decided it was time to correct it. I pulled open the hood and with a bright light looked at everything. The circuit breaker seemed to be a bit cocked in the fuse holder so I removed it and carefully replaced it fully into the fuse holder. All is well. Wish all fixes were this easy. Thanks for your support.
03-09-2019, 09:04 PM | #2 |
Re: Update on starting problem
I had a problem with my starter and found out it was the placement of the fuse as well
03-09-2019, 10:35 PM | #3 |
Thanks for the up date.
Often suggestions are made and we never find out what the actual problem was. Chris W. |
03-10-2019, 07:23 AM | #4 |
Good news. Thanks for the update. I know that I have pulled the fuse to work on something electrical on my car and then tried to start more than once and then remembered to re set the fuse.
How about when in a parking lot you get ready to leave , start her up, back out of your parking spot, lots of folks looking and smiling then the engine dies because you for forgot to open the fuel valve. Good news mine is under the dash and I don't have to get out to remedy the problem. Chap |
03-10-2019, 11:24 AM | #5 |
Davey,
Use the G.M. bayonet type circuit breaker, with the supplied pig tail. They're FOOL PROOF!!!----Use a 30 Amp one. Bill W.
03-10-2019, 10:53 PM | #6 |
Dave the un-electrician. |
03-11-2019, 10:33 PM | #7 |
Put the circuit breaker in this morning and started right up and we drove off for coffee. When I got home it hooded the starter area and removed the circuit breaker. No little spark now. Guessing the circuit breaker can be fitted too close to the rear of the fuse holder and leak a few amps so that the battery will be dead in the morning. I removed it a few times and still no spark so I made sure it was centered and will try it tomorrow. It never has shown discharge on the ampmeter even when I could detect a spark removing the circuit breaker or fuse, depending on which I had put in there. Also never could get a meter reading across the fuse holder, so I'm not real sure where the draw occurs that sometimes kills the battery.
03-12-2019, 12:33 AM | #8 |
Dave, why don't you install a proper shut off switch instead of fiddling with your circuit breaker. A shut off switch, if wired properly, will shut off ALL power from the battery while it is resting overnight.
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 03-12-2019 at 08:23 PM. |
03-12-2019, 01:46 PM | #9 |
DITTO
Paul in CT |
03-12-2019, 07:21 PM | #10 |
Also, if your battery is draining when the car sits, one important thing to check is to ensure that your generator cut-off is working properly.
Ken
Style beats speed any day, and with a lot fewer tickets. |
03-12-2019, 10:48 PM | #11 |
Ken,
I'm using alternators on both cars now. a understand there is a tiny bit of draw when the car is not running. Something about keeping the alternator ready for action. Electricity and women I don't understand. Sometime one more than the other but enjoy having both around so I guess I have learned to live with some mood swings. I think I do have a proper shut off but know I want to mount it in the cab and I don't have cables for that yet. I joined the procrastinators club, but haven't mailed in my dues yet. So much to do, so little time. |
03-13-2019, 07:06 PM | #12 |
A sticking brake light switch will drain a battery quickly, sounds like your driving it every couple of days, so your alternator shouldn't drain the battery if it's a good alternator!
03-13-2019, 11:35 PM | #13 |
My shutdown procedure includes always checking the Ammeter. Got into this habit because my brake linkage is worn and the pedal does not always return fully which leaves the brake light on. This only happens when the truck is sitting and motor not running. If I pull the brake pedal back with my toe, the linkage fully returns.
