Old 04-29-2019, 06:27 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default Brake Shoe Arching LA/San Fernando Valley
I had my shoes relined by Valley Friction in North Hollywood. But due to Haz Mat laws they can't arch them. Is the anyone in the San Fernando Valley or Los Angeles area who has a arching grinder?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 04-29-2019, 06:50 PM   #2
Talkwrench
Talkwrench's Avatar
Default Re: Brake Shoe Arching LA/San Fernando Valley
If they measured for the correct linings / thickness then you shouldn't have to.
Old 04-29-2019, 07:03 PM   #3
J Franklin
J Franklin's Avatar
These guys are good and did my work 40+ years ago. Delmers precision brake in Santa Monica. Maybe they could help you out.
Old 04-29-2019, 08:17 PM   #4
Chris Haynes
I remember Delmer's from my days living in Santa Monica. It's hard to believe that they are still business 60 years later.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 04-29-2019, 09:13 PM   #5
Tinker
Tinker's Avatar
They are craiglist and such from time to time. Delco units. Maybe get one and be the goto guy in that area??? Picked up a barrett drum cutter for about 200$. 1.75" chuck. Not that anyone would send you 4 drums across country .
Old 04-29-2019, 11:52 PM   #6
J Franklin
J Franklin's Avatar
I like to use shops that were around when our cars were young.
Old 04-30-2019, 12:03 AM   #7
Tinker
Tinker's Avatar
Are they still in business?
Old 04-30-2019, 05:44 AM   #8
Terry,OH
Terry,OH's Avatar
Lacy at the Early V8 Garage in West Covina 855 268 0325
Old 04-30-2019, 07:11 AM   #9
Sod Buster
Sod Buster's Avatar
I just did mine myself using a table belt sander, I took them slowly down until the drum would fit over the shoes, then laid a piece of sandpaper in the drum and sanded the shoe by turning it back and forth until I had a smooth arced surface.
I had the same problem finding someone that offers the service, the brakes work fine.
Sod Buster is offline   Reply With Quote
Old 04-30-2019, 07:15 AM   #10
Tim Ayers
I was going to suggest this as well.
Old 04-30-2019, 11:59 AM   #11
Chris Haynes
Too bad you were breathing that dust.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 04-30-2019, 12:00 PM   #12
Chris Haynes
I haven't heard of this shop. Thank you.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 04-30-2019, 08:19 PM   #13
Sod Buster
Sod Buster's Avatar
They make these things called dust masks.
Old 04-30-2019, 08:22 PM   #14
cas3
the epa thinks you will die looking at dust from across the street
Old 04-30-2019, 11:22 PM   #15
expavr
expavr's Avatar
TrucParCo in Anaheim turned the drums and arced the shoes to match on my tonner. This was back in 2005. http://truckandautosupply.com/
expavr is offline   Reply With Quote
Old 05-01-2019, 05:43 AM   #16
51woodie
51woodie's Avatar
I installed a set of Boling Brothers "Lincoln" brakes on the '46 last year, and was disappointed with the performance of the brakes. I pulled the drums after several hundred miles, and saw that the contact area of each shoe was only about 50-60% of the lining length. Old school brake shops are not easy to find to have the shoes arced, so like Sod Buster, I measured and sanded the high spots to get a better contact pattern. I was surprised at the variance in the thickness of the lining material, and they were certainly not arced to fit a 12" drum. So far, the brake effort has improved, but I will pull the drums again at a later date to see how successful my job was.
51woodie is offline   Reply With Quote
Old 05-01-2019, 05:54 AM   #17
51woodie
51woodie's Avatar
I forgot to include the second picture.
Old 05-01-2019, 06:58 AM   #18
Tim Ayers
I just learned this trick. Get a drum that's maybe over .060" and have it turned. Whiz wheel the mounting face off so you just have a ring. You can use the ring to help you gauge contact with the shoes. Give you a could visual of what's going on with the brakes.
Old 05-01-2019, 12:32 PM   #19
Chris Haynes
Sadly Delmers Precision Brakes phone is disconnected.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 05-01-2019, 02:30 PM   #20
JSeery
JSeery's Avatar
51Woodie's second photo.
