Old 09-29-2015, 12:12 PM   #1
Bolts
Bolts's Avatar
Default From someone who knows
First thing to do after you bring that barn find home. Buy, borrow or otherwise secure an empty shop vac (must be empty to start).
Remove the seat(s).
Bounce them around on the garage floor.
Vacuum up the 1,000,000 mouse turds off the garage floor.
Nothing wrong with it except for the name on the front.
Alex
Bolts is offline   Reply With Quote
Old 09-29-2015, 12:16 PM   #2
30-9
Default Re: From someone who knows
Shop vac must be empty? Wow that's a lot of mouse turd
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 09-29-2015, 12:22 PM   #3
ford38v8
ford38v8's Avatar
Must improve your gas mileage tremendously!
Alan
Old 09-29-2015, 12:29 PM   #4
flatheadmurre
flatheadmurre's Avatar
Next vacuum the ratsnest out of the radiator....
Old 09-29-2015, 12:35 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
Don't clean out the exhaust pipe, why?, because I like to see the acorns and various nuts get blown out on first start up.
Old 09-29-2015, 12:42 PM   #6
jacob smith
jacob smith's Avatar
glove box do not forget the glove box. The rodents love to live in there.
Ford
jacob smith is offline   Reply With Quote
Old 09-29-2015, 01:49 PM   #7
38coop
I found a rat nest in the frame of my 49 last week. I killed the rat several months ago but never could find his nest until last week. I don't know how I will get it out.
38coop is offline   Reply With Quote
Old 09-29-2015, 03:27 PM   #8
scrapiron
Leaf blower
scrapiron is offline   Reply With Quote
Old 09-29-2015, 03:33 PM   #9
39topless
Just the opposite, leaf sucker (the old shop vac again).
39topless is offline   Reply With Quote
Old 09-29-2015, 05:53 PM   #10
russcc
A word of caution about using a vac to clean up mouse or rodent debris, Those little buggers can be carriers of some nasty diseases, so you don't want to put that stuff into air circulation with a vac. I would check with the Center for Disease Control to see what they recommend, or Google it. Your local county extension service may be able to shed some light on the issues for you. Possibly wetting the debris 1st with a disinfectant, then using a wet vac, or possibly use HEPA filter in the vac. No matter how you do it, check with the experts first. My field of work is safety.
Old 09-29-2015, 06:41 PM   #11
Bolts
Bolts's Avatar
I see now that the title of my thread should have been: From someone who knows his car has not had live rodents in it for a long time.
I was actually wondering if I had exposed myself to the Hantavirus by cleaning out all that crap yesterday. Thing is, I had been driving the car and working inside it lying on the floor and being in other contorted positions inside the car with those filthy seats still in there over a period of years actually, so if I was going to get sick from it, I had had plenty of exposure.
I was trying to be facetious in my thread, as it is quite common for old cars to have mouse homes in them, I thought it would ring a familiar note with some of the members.
After the last post, I did some research about Hantavirus and was happy to learn that the virus doesn't last very long (maybe a week, not a month probably).
Here is some information from a paper on the web about Hantavirus infection.
How long can Hantavirus remain infectious in the environment? - The length of time
Hantaviruses can remain infectious in the environment is variable and depends on conditions,
such as temperature and humidity, whether the virus is indoors or outdoors or exposed to the
sun, and even on the rodent’s diet (which would affect the chemistry of its urine). Survival of
the virus for 2 or 3 days has been shown at normal room temperature. Exposure to sunlight
will decrease the time of viability, and freezing temperatures will actually increase the time
that the virus survives. Since the survival of infectious virus is measured in terms of hours or
days, only active infestations of infected rodents result in conditions that are likely to lead to
human Hantavirus infection.
So now, I don't worry about the mouse crap I cleaned up, but it is something to know about for all of us who might never give it a second thought.
Alex
Old 09-29-2015, 07:01 PM   #12
larry butcher
During the winter of 2010, I began to work on my latest collector car; a 1948 Lincoln Continental Coupe. This car sat in tall wet grass for about 6-7
years. The usual nesting of field mice. The worst had to be the headliner,at
least 10 pounds of nesting, droppings, new born infants. Didn't bother to
clean , just razor knife the perimeter and dumped it in the dumpster. Let it "airout" and wrapped it tight and stored in dry area for future reference!
larry butcher is offline   Reply With Quote
Old 09-29-2015, 07:42 PM   #13
D. Jones
D. Jones's Avatar
When I started on my pickup it had been parked in a field since 1968. It had the usual mouse houses under the seat, in the glove box, the heater and the exhaust system but, the one that got my attention was in the bell housing. The cover for the starter drive was missing so I assume that is where they got in. I sprayed everything with bleach and let it set for a few days prior to removing the debris.
D. Jones is offline   Reply With Quote
Old 09-29-2015, 09:00 PM   #14
Mike in AZ
Mike in AZ's Avatar
under the intake??....thru the oil fill.....Mike
Mike in AZ is offline   Reply With Quote
Old 09-30-2015, 10:15 AM   #15
BrianCT
BrianCT's Avatar
MMM roasted acorns. Been there.
[FONT=Comic Sans MS]
BrianCT is offline   Reply With Quote
Old 09-30-2015, 10:34 AM   #16
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Man, I've removed many intakes, filled right to the top with mice nest, there in nothing in the world that will rust things up as much as mice piss, I've seen them rust holes right through the main oil pipe. Wouldn't you like to have white one in a cage at home? Walt
Old 09-30-2015, 10:35 AM   #17
Mike51Merc
Mike51Merc's Avatar
If you borrowed my shop vac to do that, I'd be mighty pi$$ed off. Go buy yer own shop vac!
Mike51Merc is offline   Reply With Quote
Old 09-30-2015, 10:42 AM   #18
flatheadmurre
How about have them geneticly manipulated to prefer Mazda
Old 09-30-2015, 10:49 AM   #19
Tinker
Tinker's Avatar
There was mouse turds an inch deep in my 38. Took almost 2yrs for the smell to subside after a very thorough cleaning...
Old 09-30-2015, 08:39 PM   #20
1938 Coupe
1938 Coupe's Avatar
Old cars are small potatoes in comparison to what mice can do in your motorhome!
I was having work done to my motorhome in a repair center and within a week mice moved in and mice droppings were found in every closet and draw. Droppings everywhere from the bed to dashboard. I finally got them out by setting traps and poison bate.
"DON'T CRUSH IT....RESTORE IT"
1938 Coupe is offline   Reply With Quote
