04-26-2021, 08:57 AM | #1 |
1936 Temp gauge with red die, special fitting
I have a temp gauge with the red die. When I went to install it in my 59AB, The fitting fits but there is nothing to hold the bulb in place. I believe it to be a 1936 gauge and want to use in my 36 pickup. Is there a special fitting for that purpose, otherwise is there another way or place to install it? Thanks Ron
04-26-2021, 11:33 AM | #2 |
Re: 1936 Temp gauge with red die, special fitting
You are missing the adapter.Southside Obsolete in MN,35tn both members here has those I'm sure.
04-26-2021, 11:59 AM | #3 |
Are you missing the nut that holds the bulb in?
04-26-2021, 12:59 PM | #4 |
I have the nut above the bulb, but nothing to keep the bulb in place and seal it. Ron
04-26-2021, 01:11 PM | #5 |
You should be able to buy those fittings. I have used them from an aftermarket water gauge kit. (after I cracked mine from overtighting)
04-26-2021, 01:36 PM | #6 |
