Old 04-10-2018, 03:35 PM   #1
Nathan_1929
Nathan_1929's Avatar
Default '29 CCPU seat shopping - what do I need?
I'm in the market for a seat for my 1929 Closed Cab Pickup. This is what I'm working with.
I want to stay stock, so no minivan or S-10 or anything else. I've mentally swallowed the pill for the cost of a new complete seat from one of the current suppliers but I don't know what other mounting hardware I'm missing here and have no local reference to check. So what am I missing?
(I would also be in the market for any of the above if tall y'all have this for sale near St Louis, MO.)
Nathan - 1929 Closed Cab Pickup, 1929 Tudor, 1930 Coupe, 1941 Pickup - Vintage BMW Motorcycle Collector/Mechanic
Nathan_1929 is offline   Reply With Quote
Old 04-10-2018, 03:57 PM   #2
SSsssteamer
SSsssteamer's Avatar
Default Re: '29 CCPU seat shopping - what do I need?
There is a missing horizontal seat support board that goes between the floor pan and the bottom of the bench seat spring. It stands on edge. You can see the holes for its screws in the seat riser ends. Seat springs that fit properly and already upholstered are available from LaBarronBonney upholstery. Excellent quality and fairly priced.
SSsssteamer is offline   Reply With Quote
Old 04-10-2018, 04:26 PM   #3
Bob C
Here are some pictures Marco posted.
Bob
Old 04-10-2018, 05:35 PM   #4
JaxFLG8r
I do not know if the CCPU is different from the RPU, but this is what we had.
We had a piece of plywood in the shape of the bottom seat spring with holes drilled in to let air out when sat upon. The seat spring is attached to the plywood base, and the padding goes on top of the spring followed by the seat cover.
The only attachment is the board I attached to the bottom of the seat base, that will "lock" into the small pieces sticking out from the front rail which prevent frontward and side to side movement.
The back portion of the seat has padding and the seat cover, and it rests on top of the bottom seat assembly, and "clips" down in the rear top.
Hopefully your CCPU set up is similar. Ed Williamson
JaxFLG8r is offline   Reply With Quote
Old 04-10-2018, 06:00 PM   #5
Bob C
There shouldn't be any wood on the seat springs.
Bob
Old 04-10-2018, 06:22 PM   #6
1955cj5
1955cj5's Avatar
We have a reproduction LeBaron Bonney seat bottom.
You can see the two clips(circled) that slip into the loops on the seat riser in the truck.
We had to re-cover it as it was stored where mice could get to it.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 04-10-2018, 08:31 PM   #7
SeaSlugs
SeaSlugs's Avatar
Ill add to this - that missing board also has screws from under the cab into the board as well. (note the row of screw holes in the under seat pan) Study marcos pics - your center 2 seatback supports should have a pointy dagger things riveted to the wood towards the bottom - this is what holds the rear of the seat up.
Do i dare ask what the lebaron boney pre-upholstered seats cost? (probably a deal if one has no seat springs nor cover to work with or go by)
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-11-2018, 09:31 AM   #8
Neil Wilson
Neil Wilson's Avatar
If you want to have original Ford looking seats (i.e. stock), then LeBaron Bonney covered seats are not the way to go. They are not close to being correct unless they have changed in the last couple of years. They don't look at all like the originals shown in the above #5 post photo. If you just want to have seats that work, then use them.
Vendors sell the springs which are close to original. You will likely need these since finding usable original springs are just about impossible.
Page E62 of the RGJS has some info/pictures covering upholstery and backrest retainer hardware.
I have a folder of pictures/information regarding 82-A closed cab seats I will share. Email me your request to [email protected]
The attached picture shows the seat support wood.
File Type: jpg 82-A Seat Riser & Seat Back Boards 2.jpg (180.9 KB, 105 views)
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
Old 04-11-2018, 12:53 PM   #9
Nathan_1929
Thanks for the info, pals.
I've emailed you, Neil.
I have been set on getting a LeBaron Bonney seat.. just waiting for their material sample packet to arrive so I can brainstorm a bit. But, if folks have a compelling reason to avoid them, I'm all ears.
Old 04-11-2018, 01:44 PM   #10
CHuDWah
CHuDWah's Avatar
FWIW, here's a pic of a full L-B interior, including their springs upholstered by them, in a 30 82-B. It was installed 30+ years ago but I doubt L-B has changed it much since. It isn't an exact duplicate of original but is high quality and serviceable. It was easy to install and fit with very little "adjustment".
File Type: jpg 1930 Ford Model A Closed Cab Pickup Interior Left 3.jpg (55.4 KB, 95 views)
CHuDWah is offline   Reply With Quote
Old 04-11-2018, 02:38 PM   #11
SeaSlugs
SeaSlugs's Avatar
Looks very presentable
Old 04-11-2018, 06:20 PM   #12
CHuDWah
CHuDWah's Avatar
Thanks! Sadly, truck was sold many moons ago.
Since you asked, upholstered springs are $1,045 - the price is one thing L-B changed in 30 years! Here's their webpage where you can put in make, year and body style to see their kits and prices:
https://www.lebaronbonney.com/cart/comp_kits.php
Old 04-11-2018, 07:53 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
The last examples I saw, LB had the seam right on the edge with no tucks around the corners, which is not correct.
Classtique from Minnesota had the seam lower and had folds at the corners, as original seats have.
Old 04-11-2018, 08:13 PM   #14
Dan Partain
Dan Partain's Avatar
Tom is correct, here's a couple of photos of the front corner on an original seat bottom.
-DAN
Dan Partain is offline   Reply With Quote
Old 04-11-2018, 08:51 PM   #15
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Nathan,
You may want to consider getting the modified seat springs.
The bottom cushion is 2 inches shorter and the upper spring is 2" taller.
It is recommended for taller drivers.
Also, some drivers do not use the back wood for the same reason.
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 05-13-2018, 03:10 PM   #16
Papa's CCPU
Papa's CCPU's Avatar
Anyone have pictures they can post for a vendor comparison....???
Papa's CCPU is offline   Reply With Quote
Old 05-13-2018, 07:07 PM   #17
1955cj5
1955cj5's Avatar
This is not a great picture.....and I can't find one with the seats installed...
But this is a LB back and bottom for the 29 ccpu......easily 10 years old...maybe 20...
We had to remove the bottom cover and replace the jute and padding as a result of mice..but the cover was OK so we reused it.
Old 05-13-2018, 08:01 PM   #18
Papa's CCPU
Was about to place an order this week for springs, and then the seat kit....need to rethink that now....thanks for the photo.....
Old 05-13-2018, 08:13 PM   #19
1955cj5
1955cj5's Avatar
If you were going to assemble it yourself....maybe a re-think is in order....we initially called LB about the upholstery kit but went with local supplies and reused the cover....still quite a project...Hog ring pliers and lots and lots of hog rings.........jute, foam and batting.......but my wife helped and it was fun....once!
Old 05-15-2018, 01:54 PM   #20
Papa's CCPU
Neil, I have contacted you in the past regarding my 82-A cab....I am now getting things going and this thread thankfully stopped me in my tracks before ordering seat cover materials.....
Would you consider as Tom mentioned in post #13 that Classtique makes a closer to original set of covers????
Have contacted them but they have no images available showing there finished product...
Any help appreciated
Thanks,
Mike
