Old 02-13-2020, 12:30 PM   #1
37 Coupe
37 Coupe's Avatar
Default 1931 USA made brake light switch issues.
Has anyone else eevr spent the extra money at $49.95 to buy the USA made stop light switch only to have it malfunction? I know it is the switch or I assume it is because everything works when I jump the two wires on the switch.It works at first but as the plunger comes out even more when brake pedal is fully depressed the lights go off.In other words the switch seems to have an off-on-off position. I am going to contact the supplier and see if they have had an issue with any of them.Doubt a return adjustment will be made after having it a year before installing with new harness. I may start looking for an Ampco or someother old NORS one that show up on Ebay.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 02-14-2020, 09:51 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: 1931 USA made brake light switch issues.
The crossmember mounted switch is normally closed. These are pretty simple and can probably be fixed.
Old 02-14-2020, 10:07 AM   #3
37 Coupe
37 Coupe's Avatar
I know it is closed fine and at first pedal depression it opens and lights come on,then as more pedal more open no lights. Jumped across fine. Guess if Bratton's won't respond I will take apart not what I wanted to do,why I spent $50.00
Old 02-14-2020, 11:49 AM   #4
Shelbycsx
I just got this one on ebay
Shelbycsx is offline   Reply With Quote
Old 02-14-2020, 12:08 PM   #5
Merc Cruzer
Merc Cruzer's Avatar
Just a thought, but the one you bought can probably be repaired for a number of years, if need be, where as the off shore ones are just throw-a-ways. I have taken allot of the original items on the car apart and serviced them, then put them back in, and they perform perfectly.
When you do it, you will know how it works and it will be better than new. You get the satisfaction of a job well done, to your standards.
Merc Cruzer is offline   Reply With Quote
Old 02-14-2020, 12:08 PM   #6
ryanheacox
ryanheacox's Avatar
I believe A&L is the maker of that switch. I'd give them a call on Monday and see what they say. Probably just a fluke. They make very high quality products but there are only a couple people working there. I can see how something could slip through QC once in a while.
ryanheacox is offline   Reply With Quote
Old 02-14-2020, 04:21 PM   #7
37 Coupe
37 Coupe's Avatar
That is what I will do and hope they don't mind since I bought it from Bratton's but they have not got back to me. Order this weekend goes to Snyders.
Old 02-14-2020, 04:38 PM   #8
Ed in Maine
If that switch has brass bushings it is most likely made by A & L Parts. They are a quality manufacturer and I believe they will make good on it. I have had these switches apart in the past and you will be surprised at how simple they are. Before you get into it try to contact A & L first. If that fails, they carefully open the tabs and look inside. You will be able to see why it doesn't work. Good luck with it, Ed
Ed in Maine is offline   Reply With Quote
Old 02-14-2020, 04:53 PM   #9
Charlie Stephens
Here is the one from A&L which I assume Bratton's is selling as their high quality switch. Note the brass bushing at each end of the shaft. Does yours have these brass bushings, maybe they sent you the cheap one by mistake?
Charlie Stephens
Old 02-14-2020, 07:27 PM   #10
Flathead
Flathead's Avatar
Yes A&L is a quality operation and that is a good switch that they offer, I have one in my car with no problems. As Charlie suggested verify that you in fact do have the good switch.
Flathead is offline   Reply With Quote
Old 02-14-2020, 08:54 PM   #11
37 Coupe
37 Coupe's Avatar
Charlie Stephens
Yes that is the one with the brass bushings and it cost $49.95.I will call A and L next week and explain to them what it is doing, off-on-off.
Old 02-14-2020, 11:23 PM   #12
Jeff/Illinois
Jeff/Illinois's Avatar
Before I'd do that, ordering another part, I'd take the one you have apart and check it out. Not a big job.
This is the first I ever heard of A&L's switches not working something is weird about this.
Jeff/Illinois is offline   Reply With Quote
Thread Tools
Display Modes
