Old 10-18-2013, 08:21 PM   #1
Hondamate
Default W?hat is this
What is this horn thing and what is that metal tube coming off of the intake manifold? Thanks
Hondamate is offline   Reply With Quote
Old 10-18-2013, 08:25 PM   #2
kwisor
kwisor's Avatar
Default Re: W?hat is this
hello
not sure about the horn thing but the tube from the in take is a vacume line for the wiper motor
kevin
1930 model a tudor
1923 model t roadster p/u
kwisor is offline   Reply With Quote
Old 10-18-2013, 08:36 PM   #3
montanafordman
montanafordman's Avatar
The "horn" is the intake for a heater. It ducts air over the hot exhaust manifold into the car for heat. Usually there is a hole cut in the firewall behind the manifold heater to pass the heat and it doesn't look like your car has the hole cut. This was an aftermarket accessory for the Model A since they did not come from the factory with a heater. The line coming off the intake manifold supplies vacuum pressure to run the windshield wiper.
Aaron in Tacoma
(although still a Montana hillbilly at heart )
montanafordman is offline   Reply With Quote
Old 10-18-2013, 08:47 PM   #4
Hondamate
Originally Posted by kwisor View Post
hello
kevin
1930 model a tudor
Thanks
Ok, my model aa has the hole. Thanks
Old 10-18-2013, 10:42 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
On the choke rod you should have a long spring that pushes the grommet against the firewall. Your's looks to be in the middle of the rod.
Thread Tools
Display Modes
