Old 07-06-2019, 01:17 AM   #1
Jeff M
Default Brake Banjo Bolt
I ran hydraulic brakes on an A coupe like a '39-'48, but I'm having a hard time getting the banjo bolt T to seal. With pressure on the system I get a very faint seeping around the bolt head side of the washer. And yes, I annealed the copper washers and tightened the bolt as much as it would go. I read on here that the original style crush washers had rings like the brass junction, is that true? Some of concentric rings on the reproduction brass junction seem to be of poor quality. I assume they should be void of nicks and deformed edges to get a proper seal. The bolt was an NOS Ford unit with the correct recessed taper.
Has anyone else had this issue? Any ideas?
Jeff M is offline   Reply With Quote
Old 07-06-2019, 01:23 AM   #2
Tinker
Tinker's Avatar
Default Re: Brake Banjo Bolt
Ugh banjos can be problematic. Block could be bad or other. Including installation.
Not sure if Lacy is still selling parts. They do conversions but I'm sure they would sell you a few parts needed. Give them a ring.
http://www.earlyv8garage.net/
Old 07-06-2019, 04:14 AM   #3
deuce lover
deuce lover's Avatar
Get the correct washers.The Ford Store in San Dimas,CA has them.
Old 07-06-2019, 06:08 AM   #4
Terry,OH
Terry,OH's Avatar
This is typical add a second washer under the head.
Old 07-06-2019, 05:21 PM   #5
Jeff M
The washers I'm using are from the Early Ford Store, but they are just the solid copper ones. Did the original washers have concentric rings like the brass block?
You put two washers under the head of the correct OEM bolt?
Old 07-06-2019, 06:00 PM   #6
Russ/40
Russ/40's Avatar
Yes, I have had that problem on the brake system on my '40. Running DOT5 and just could not get the seep stopped. It was crazy. Tried several copper washers. I ended up using a nylon washer which solved the issue.
Old 07-06-2019, 06:16 PM   #7
aussie merc
aussie merc's Avatar
old trick tin the copper washer with lead free solder
aussie merc is offline   Reply With Quote
Old 07-06-2019, 06:38 PM   #8
PeteVS
PeteVS's Avatar
I put hydraulics in my brother's '32 and it still leaks. All new parts, washers from different sources. I like the idea of tinning the copper washer. I'm wondering if there's a reason "Aussie merc" recommends lead free.
Old 07-06-2019, 09:18 PM   #9
Phil Gillespie
Phil Gillespie's Avatar
Anneal the copper washers normally works fine for me.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 07-06-2019, 09:41 PM   #10
aussie merc
some brake fluids over time will attack the lead and start leaking also lead free is slightly harder than solder containing lead so can stand higher pressures
Old 07-07-2019, 07:05 AM   #11
john in illinois
john in illinois's Avatar
If you leave one washer off can you still snug the bolt up. I remember having one bottom out and having to shorten it. Not sure if it was this application.
John
Welcome each day
john in illinois is online now   Reply With Quote
Old 07-07-2019, 08:39 AM   #12
Kube
Kube's Avatar
Okay, now this advice I'm going to file away. Thanks for the tip. I've been fortunate for all of these past years - no leaks. But, who knows what the future holds. Thanks again.
Old 07-07-2019, 12:46 PM   #13
Jeff M
John
I'll give that a try when I blow it back apart, however I do remember four threads sticking out of the bolt with it through the block with a washer on each side, which should be correct. I'm starting to think it might just be a bad brass block, the concentric rings might be machined bad. I ordered two more from two different places to check out. The washer on the hose side of the block sealed fine.
Do you guys tap the head of the bolt as you tighten it or just snug it up tight? I've heard tapping it can help seat the crush washers as you tighten without just relying on thread torque.
