Old 06-22-2022, 09:11 AM   #21
Ziggster
Default Re: Oil Pump Rebuild Question
Thanks! They are not perfect. Michael at 3rd Gen says the pump should be fine with 0.006” clearance between the gears. Seems much higher than similarity designed oil pumps, but I trust his word.
I also noticed that there seems to be this extra part (second from left). The other pump I have does not have it, and I don’t see it in the exploded views I looked at.
File Type: jpg 48CA012B-3FE9-409F-9FF5-A43311F52B51.jpg (99.6 KB, 35 views)
Ziggster is offline   Reply With Quote
Old 06-24-2022, 08:16 PM   #22
Ziggster
Was doing “final” assembly and noticed the original cam drive gear was damaged where the solid pin was located. I mentioned I had a hard time getting the pin out. Even so, I’m really surprised the gear collar was damaged in such a manner. Luckily, I had the drive gear from the aftermarket oil pump. Getting that on wasn’t easy either as the gear ended up cocked a bit even with the split pin (from the aftermarket oil pump) through all the drive shaft and gear on one side. Really strange. Tapping it with a brass hammer got the hole aligned with the pin.
Damaged area around where the pin passed through the cam drive gear of the original oil pump. No such damage on the cam drive gear from the aftermarket pump.
File Type: jpg 631F27D9-D203-4ECC-9069-F6F73ED13EE3.jpg (19.5 KB, 24 views)
File Type: jpg 84AD76F5-C83C-46A7-B039-E0DE138DE3A8.jpg (17.4 KB, 20 views)
Old 06-25-2022, 06:53 AM   #23
Ziggster
Forgot to include some pics of the finished assembly.
File Type: jpg C9174E56-15AF-4D4E-9357-B1212E71D6E7.jpg (48.5 KB, 17 views)
File Type: jpg B1945AE6-0FC4-4B50-AC77-76ED6747AEED.jpg (44.7 KB, 16 views)
File Type: jpg 7AC661F9-22B9-42F3-B14B-F59027750F79.jpg (56.2 KB, 18 views)
Old 07-13-2022, 04:04 PM   #24
Ziggster
Just received the gaskets yesterday for the bottom gear cover plate and pickup tube so fitting/flange so decided to finish off the assembly. Couldn’t find any torque specs for the bolts, so just assumed they were equivalent to Gr 5 (1/4-28) and torqued them to 7.3 ft-lbs (88 in-lbs) which felt about right. Same for the pressure relief valve cap, so torqued it to about 12-15 ft-lbs based on just the feel/resistance. Didn’t have any blue thread locker on hand so hoping the split lock washers and correct torque will suffice. Had some stainless steel wire laying around so used it to secure the cap for the pressure relief valve. Also replaced the original copper? washer with the fibre one that came with the other gaskets. Used the old drill trick to twist the wires together which worked great. With the addition of the bottom cover gasket, the gears spin very nicely without any rubbing or resistance. I also noticed the gasket for the gear cover plate extends past the edges of the cover and housing slightly. Not sure if I should trim it.
File Type: jpg B7E26C0A-5D0B-4961-B249-4E3D25491569.jpg (28.0 KB, 15 views)
File Type: jpg FFFF9C7B-B1E0-4551-970B-0963E6383651.jpg (46.4 KB, 14 views)
File Type: jpg E0906A36-A846-47BC-B7D1-CD773E9D13EB.jpg (33.4 KB, 16 views)
