05-19-2018, 01:50 PM | #1 |
1936 hood trim installation
I have a new reproduction set of hood trim and clips for my ‘36 coupe. Would someone offer some advice on how to install the clips in the trim and through those little holes in the hood sides with out damaging the stainless trim?
Thank you! Tim |
05-19-2018, 04:46 PM | #2 |
Re: 1936 hood trim installation
Just did the same thing with the stainless surround on my 1936 Pickup grille. Get a piece of 1x4 pine about 12 long. The clips should not matter if they are slid in with the curve one way or the other. Take a rubber hammer and with the first clip over the hole, place the pine board (long ways) over the stainless where the clip is and give it a pound. Scary-- yes, but the clips go in with minimal damage to the paint. If you are sliding in more that one clip at a time, make sure the others are over the holes that they will be going in before pounding the first one. As they say -- It worked for me.
05-19-2018, 05:05 PM | #3 | |
05-19-2018, 07:29 PM | #4 |
No -- the clips are loose in the stainless channel (remember, I am speaking about the grille trim for a pickup). I believe they are the same clips -- they are an oval at the top, with the 'legs' going down in the center and crossing as an 'X'.
05-19-2018, 10:07 PM | #5 |
A friend and I just recently installed the hood trim and clips on a 36 Ford Coupe.
Previous experience by me found it difficult to install the clips in the louver area in particular. We install paper under the area of the trim and close to the holes and then aligned the clips in the holes and held in place with masking tape. We then grabbed the clip on the inside with a vise grip and pulled them into position. The paper protects the paint when the clip pops into place. I have done other hoods with very good results. Obviously you need thin paper to easily remove after the trim is all installed on each hood side. |
05-20-2018, 11:33 AM | #6 |
When I slide the clip in oriented parallel to the trim, it’s very loose. When I tried to squeeze a clip enough to fit it in perpendicular to the trim, it kinda mangles up the clip. Thanks, again, for the help! |
05-20-2018, 05:47 PM | #7 |
The ones I removed from my '36 were parallel (picture #1). of course, in the last 80-years they have probably been disturbed, but I can't imagine trying to insert then perpendicular.
05-20-2018, 06:18 PM | #8 | |
It should remain captured by the lip of the molding. If it does not come out then you are good to go. It has to allow for some movement of the molding for alignment purposes. If the clip comes out it is too small.
05-20-2018, 07:56 PM | #9 |
Thanks TagMan and 51 Merc-CT!
When I slide the clips in as in pic 1, I can work it out by rotating the clip, but knowing this is the correct way, I think I can massage the clips a little to ensure they stay in the trim piece. Moving forward now! Thank you, very much, for everybody’s help! |
