Old 05-07-2018, 11:06 PM   #1
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default Got Paint?!
Posted previously on the cheapo frame rotisserie I made and I finally got some paint on the frame today. The rotisserie has really made the job quite easy ....
I am using some stuff called KBS Coatings and they have frame paint and engine paint in all kinds if colors you put on with a brush that looks sprayed. It needs something of a profile (roughed surface) to adhere to. Thought I would pass this info to fellow Barners who do not spray paint at home like me ....
A good brush and thin coats is all it takes ....
TomT/Williamsburg is offline   Reply With Quote
Old 05-08-2018, 05:00 AM   #2
ford nut
ford nut's Avatar
Default Re: Got Paint?!
how many qts. to do the frame?
ford nut is offline   Reply With Quote
Old 05-08-2018, 06:29 AM   #3
corvette8n
corvette8n's Avatar
Looks good, someone else told me they thought KBS worked better than Por-15.
Old 05-08-2018, 06:46 AM   #4
TomT/Williamsburg
I used about 1/3 of a qt - I would safely say you can get two frames out of of qt.
Old 05-08-2018, 06:48 AM   #5
TomT/Williamsburg
I have never used Por 15 so I cannot compare ...
Old 05-08-2018, 07:01 AM   #6
JSeery
JSeery's Avatar
Looks good!
Old 05-08-2018, 07:35 AM   #7
countrysquire
countrysquire's Avatar
I have used the KBS engine paint on my '40 and really liked it. It self levels so there are no brush strokes, which is nice if you are painting the engine while still in the car. The finish is very glossy and looks great, but I would think that it is too glossy for a proper restoration.
countrysquire is offline   Reply With Quote
Old 05-08-2018, 07:38 AM   #8
JSeery
JSeery's Avatar
Well, in Tom's case, that is obviously not a restoration!
Old 05-08-2018, 07:44 AM   #9
sidevalve8ba
sidevalve8ba's Avatar
Thanks Tom. I'll keep that stuff in mind.
sidevalve8ba is offline   Reply With Quote
Old 05-08-2018, 07:47 AM   #10
countrysquire
True, and probably the case for most of us.
Old 05-08-2018, 08:16 AM   #11
zzlegend
zzlegend's Avatar
That looks nice Tom. And just to add,,,,,,that nobody has lived until they have spray painted a frame with an Xmember. Nooks and crannies. Mark.
zzlegend is offline   Reply With Quote
Old 05-08-2018, 08:24 AM   #12
TomT/Williamsburg
Ha ha - I actually cheated - the interior of the frame and all those nooks and crannies are done with Rust-Oleum! You have to create a profile for the KBS to stick and it is near impossible to do that for those interior spaces ... I will be top coating the Rust-Oleum with spray bomb for a nice finish .... there's more than one way to skin a cat!
Old 05-10-2018, 10:55 AM   #13
TomT/Williamsburg
Frame is done being painted ... not perfect but it is a highly modified non-Fordbarn friendly original frame for a hotrod which will be driven. I am starting to see the light at the end of the tunnel on this project .... started painting fuel and brake lines, pedal setup, and other misc pieces to start the final assembly ....
Old 05-10-2018, 11:49 AM   #14
V8COOPMAN
V8COOPMAN's Avatar
SHHHHhhhhhh! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 05-10-2018, 02:56 PM   #15
revkev6
did you do the three step process of clean/prime/paint that they sell the kit for??
revkev6 is offline   Reply With Quote
Old 05-11-2018, 12:05 AM   #16
outlaw
Talking Re: Got Paint?!
Originally Posted by V8COOPMAN View Post
SHHHHhhhhhh! DD
outlaw is offline   Reply With Quote
Old 05-11-2018, 10:19 AM   #17
Admiral
Admiral's Avatar
NICE WORK! I love seeing budget-friendly builds.
Admiral is offline   Reply With Quote
Old 05-11-2018, 11:35 PM   #18
TomT/Williamsburg
[QUOTE=revkev6;1627610]did you do the three step process of clean/prime/paint that they sell the kit for??[/
On metal that is not in a marine environment and that has a profile (rough surface), directly applying 2-3 thin coats works best.
Old 05-11-2018, 11:48 PM   #19
TomT/Williamsburg
Thanks guys - I love my flatheads, my old Fords, and have the greatest respect for you guys that so meticulously do restorations. It's just not me. I also know that not everyone on this forum is a restorer in the purest sense of the word so I am putting this info/idea/product out there for those who might be interested.
Old 05-19-2018, 08:13 PM   #20
fatkoop
fatkoop's Avatar
My hero!
fatkoop is offline   Reply With Quote
Old 05-19-2018, 08:25 PM   #21
Tinker
Tinker's Avatar
Looooks like deuce rails... so what goes on top? maybe I missed that.
I think.... some "restorers" don't even go to the level you are now. But some just amaze the heck out of me with their attention to detail and completeness.
Old 05-20-2018, 08:09 AM   #22
V8COOPMAN
V8COOPMAN's Avatar
Tinker......Here's the "topping". Looks like a '32 to me. Click the link below for a fairly detailed story behind his build! DD
https://www.jalopyjournal.com/forum/...thread.983419/
T5 W/TORQUE TUBE
