Old 09-21-2011, 05:02 PM   #161
jimTN
Default Re: 1937 No start
sometimes its something sooo simple. Last night I built a 9N dist and bench tested it with good spark inspite of foreign made points and condenser that had to be "fitted". My son took it and put in on his neighbors tractor and nothing. They then discovered spark plug wires were off the plugs and plugs were loose. A little tighting and varoom!
Old 09-21-2011, 05:52 PM   #162
B-O-B
B-O-B's Avatar
been so long ago I forgot but has a differant working distributor been tried. Sure would rule a lot of questions.
B-O-B is offline   Reply With Quote
Old 09-21-2011, 06:38 PM   #163
George/Maine
George/Maine's Avatar
If you check Macs Caps the wires are as TOMo in 121 post took the time to read off a cap and the are right.
Right Side Looking from fender.Number 1 is top left,2 bottom right,3is top right,4 is bottom left.
Drivers side viewed from fender bottom left is 5,bottom right is 6,top right is 7,and 8 is top left.
As I have been saying right along number 1 is innner top left or 11 oclock.
NOTE this is viewed with caps on dist "Not on bench."
also if they get swapped from one side to other it wouldn,t run.
George/Maine is offline   Reply With Quote
Old 09-22-2011, 10:52 AM   #164
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Some new information for the discussion.............
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 09-22-2011, 01:12 PM   #165
37ford4dr
37ford4dr's Avatar
so which is a better divers style distributor the first version or the second version?
37ford4dr is offline   Reply With Quote
Old 09-22-2011, 01:46 PM   #166
BUBBAS IGNITION
Ya had to ask right . We are playing with both types as many of the cars at the Newport hillclimb use our ignitions.
A fellow barner sent me a email a few days ago and got the brain cells going. He stated that we shold use the 36 distributor with the dwell adjusting screw holes in the helment bottom and remove the "make set" of contacts and use only a single set of points. This to me makes sense and in the next couple weeks i will get one done and spun up.
Stay tuned .........
[email protected]
Old 09-22-2011, 04:14 PM   #167
jimTN
That should work Bubba, early Packards had dual points and a conversion plate is made for them now to convert to single common points. I put one in my 29 and it runs fine.
Old 09-22-2011, 06:08 PM   #168
BIG MIKE
BIG MIKE's Avatar
ken You Need me here so you can Vent I know your Blood is boiling over! LMAO
BIG MIKE is offline   Reply With Quote
Old 09-24-2011, 06:05 AM   #169
JM 35 Sedan
JM 35 Sedan's Avatar
Bubba, Would it make any sense to put that distributor on a known good running engine to try it out, after you do your machine checks, before you ship it back to the owner? That way we could definitely rule out the distributor as part of the problem. JMO
Originally Posted by BUBBAS IGNITION View Post
Ya had to ask reight . We are playing with both types as many of the cars at the Newport hillclimb use our ignitions.
John
Old 09-24-2011, 08:40 AM   #170
BUBBAS IGNITION
No real advantage to using a live engine with the test equipment we use.I have side caps coming from Van Pelt and will run the entire unit with wires , loads and a view of rotor both visual as well as a scope waveform. At this point the distributor is pretty much perfect ( without wires and caps).
[email protected]
Old 09-24-2011, 09:35 AM   #171
Ratatat
Ratatat's Avatar
Well what ever happend? I see the OP hasn't been on here since 9-7. Did he ever get the car running?
Ratatat is offline   Reply With Quote
Old 09-24-2011, 04:23 PM   #172
George/Maine
After reading this problem over from first post i,m still bashing the dist.
There is maybe one more thing that has been over looked.
The timing of the of the points.
Seeing the a 2 points you have a make and brake set.
So the dist turns counterclock wise and when the first set makes,
the other is made and when it brakes "AT that time a spark should be
at slot time,putting spark say 12 oclock and slot same time.
"The rotor maybe right"" but the points cam is off"
say cam was off 30 degs and cap off 10 dges being off 40 total.
If these are new parts they could be made wrong.
Slot time is TDC,spark has to be same time,and the rotor lined up with cap.
This can be done and NO Machine is needed turn by hand.
I hate after market junk sorry.
Old 09-24-2011, 05:01 PM   #173
ken ct
So what your saying Bubba is that the dist looks perfect except for the wires and caps,which we can assume the fella put these in himself. Points to wires in wrong or caps wrong which most of us have been saying all along.This is an interesting thread and very informative for all who are following it. Love a good mystry.ken ct.
ken ct is offline   Reply With Quote
Old 09-24-2011, 06:20 PM   #174
BUBBAS IGNITION
Yep thats pretty much it. If for some reason the distributor had a problem , it certaintly doesnt now i have ran this thing to death a couple days in a row.
As far as anything being made wrong , twisted etc i have compared every part to the baskets full of the same unit more than once since i have had it.
I havent shiped as of yet as i want to see some waveforms on a scope with the side caps and wires attached, should get that done early this week and ship back to customer....
[email protected]
Old 09-24-2011, 06:51 PM   #175
ken ct
So he didn't send you the wires or caps which could still be wrong when he gets it back.And he will have the same problem.ken ct. I still think hes got the wires in the wrong holes. ken ct.OMO with out getting a look at the whole setup caps in place ,wires installed and in the tubes,the whole cheebang the way he installed them.
Old 09-24-2011, 07:03 PM   #176
George/Maine
If the points fired late say 35 to 40 degs late the rotor would be close to #4 that cylinder would be close to bottom and fired late causeing to blow back thru carb on number 4.
The car did run and he didn,t mess with wires or cap.
That make sence to me but i don,t have dist.
Old 09-24-2011, 07:13 PM   #177
ken ct
Bubba is the only one to see the dist and he only got 1/2 of it.Could have been setup wrong by previous owner and never fixed?? ken ct. I would love to get a look at this thing [the whole thing wires caps and metal tubes] all attached to the dist the way he was trying to start it. ken ct.
Old 09-24-2011, 07:16 PM   #178
Hoop
Hoop's Avatar
"Points to wires in wrong or caps wrong which most of us have been saying all along." - ken ct.
( .... psst, Ken. You started out saying it was the power valve ... )
I got beer riding on this.
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
Old 09-24-2011, 07:34 PM   #179
George/Maine
I think the points cam is off ,missing 15486372 number 5 and turning was closer to number 4 and firing 4 thur carb.
Old 09-24-2011, 08:30 PM   #180
ken ct
Well in his first post he stated it was backfireing through the carb. Its not good if hes running a 94. He never stated which carb he was useing.And still hasn't.That was a shot in the dark we all make mistakes LOL ken ct.
