05-18-2018, 11:19 AM | #1 |
59L block sleeving
I have 59L block bored 3.312, 3&5/16". The machine shop pressured tested it before they started some seat replacement work and found a leak in the #4 cylinder wall near the exhaust port. What is the thinnest sleeve you can use the to bore out that cylinder and sleeve it back to 3.312. Thank you Fordbarners.
05-18-2018, 12:52 PM | #2 |
Re: 59L block sleeving
Ford made .060 thick sleeves already finished honed
05-18-2018, 01:36 PM | #3 |
There have been flat head V8 cylinders bored through to the water jackets to get big sleeves installed. They usually leave a ledge around the bottom of the cylinder to locate & stabilize the bottom of the sleeve and good old JB Weld epoxy to help keep the cylinder and deck surfaces stable up top. One outfit did this to all eight cylinders in a 21 stud engine in order to get it out to 3 3/16" and use a 4-inch stroke crank so they could run the Great American Race in a 1935 or 36 Ford coupe (I don't remember which). It made it all the way without problems and I think it's still going. 255 CID is pretty big for an ole 221 engine. The 24 stud engines will go farther but the rest of the deck & valve pockets should be in good condition to start with.
05-18-2018, 01:44 PM | #4 |
I would think the mechine should be able to help you select a sleeve. If there is any question about cylinder wall thickness have it sonic checked.
05-18-2018, 02:10 PM | #5 |
I bought a '36 sedan that had a ton of parts with it, including a '36LB block that had the cylinder walls bored out and sleeved with 3 3/16 sleeves. It ran hot and puked water out one header when I ran it in the frame to break it in. Thought I had it sealed up and completed the car, only to have it get hot just a couple miles into the first test ride. Tore it down and one sleeve had a 3 inch vertical crack. Bad sleeve??? Who knows. In my opinion a good LB block was wrecked for no good reason. Rod
05-18-2018, 02:47 PM | #6 |
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
05-19-2018, 08:34 AM | #7 |
Thank you Fordbarners. The tip on the Ford .060 sleeve and LA Sleeve, much appreciated.
05-19-2018, 10:17 PM | #8 |
I've run these blocks bored to 3 7/16 in a stock car. Also in a 40 Ford coupe with all the rest of the goodies, and that was 20 years ago and it;s still running.
So sleeving should be OK |
05-20-2018, 06:51 PM | #9 |
I have had some Factory Ford re-builts, (Somerville MA plant), that have very thin wall sleeves.
