03-31-2018, 11:01 AM | #1 |
Castle nuts vs lock washers
I just found that my front backing plates have nuts and lock washers and not castle nuts and pins.
Do I need to change them? |
03-31-2018, 11:12 AM | #2 |
Re: Castle nuts vs lock washers
I would go back to the original setup. The correct bolts and nuts can be obtained from several supply houses like Snyder or Bert's to name a few.
03-31-2018, 12:26 PM | #3 |
Just went to Tam's Model A parts and he sold me just the nuts without the bolts.
Great guy! |
03-31-2018, 01:58 PM | #4 |
03-31-2018, 02:33 PM | #5 |
No, they have the holes.
Thanks |
03-31-2018, 04:23 PM | #6 |
1929 Model AA - Need long splash aprons! |
04-01-2018, 10:49 AM | #7 |
I'd leave it as is unless you were restoring to blue ribbon specs.
04-02-2018, 10:05 AM | #8 |
Ditto
04-02-2018, 11:37 AM | #9 |
If it is set up correctly the LW's will hold. When you take them apart then you can go back to pins and castle nuts.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
Thread Tools | |
Display Modes | |
