Old 08-06-2019, 07:41 AM   #1
Tinbasher
Tinbasher's Avatar
Default Your Thoughts on this one.
As you can see from the picture my car is tilting to the drivers side. I've checked the centre bolt in the rear spring and it is in the crossmember. The shocks are installed and the frame is straight and level. Tire pressures are good any idea's?
JP
Tinbasher is offline   Reply With Quote
Old 08-06-2019, 07:46 AM   #2
wmws
Default Re: Your Thoughts on this one.
Very common problem. The drivers side springs are sagging from the drivers weight all these years. Just turn them around.
wmws is offline   Reply With Quote
Old 08-06-2019, 08:41 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
Lean to the side is caused by friction between spring leaves. Give the front and rear springs a heavy dosing with WD40 so it gets between the leaves. Spring covers soaked with 140 gear oil will do wonders to fix the lean and improve the cars ride.
Bob Bidonde
Old 08-06-2019, 08:43 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
It could be that the U-bolts on the drivers side of the springs were tightened more than the passenger side . Just a guess .
Old 08-06-2019, 10:37 AM   #5
alexiskai
alexiskai's Avatar
I'm intrigued by this recommendation because I have this problem and I really don't want to go to the trouble of removing the springs.
However... WD-40 is primarily a solvent, it's not really designed to cling and lubricate. Does this really work? Would it work better with, e.g., a spray-based silicone lubricant?
Old 08-06-2019, 11:12 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
I squirted my springs with automatic transmission fluid, it penetrates well , but you need property operating shocks---- now the spring returns the car to level when I get out
Old 08-06-2019, 11:39 AM   #7
Marshall V. Daut
Check your private messages on this website.
Marshall
Marshall V. Daut is offline   Reply With Quote
