11-26-2019, 04:39 PM | #1 |
Bolt sizes for condenser
What are correct bolts and length for bolt that goes into distributor body and bolt that goes into the end of the condenser. Thanks for help I’ve been using incorrect sizes and snugging them up with split washers.
Help appreciated my email is [email protected]. Pete |
11-26-2019, 05:32 PM | #2 |
Re: Bolt sizes for condenser
Condenser has two screws the ground tab one is 8-32x1/4 w/washer,for end of condenser-10-32x7/32 no washer,not sure what you mean by distributor body?
www.whidbeymodelaclub.com |
11-27-2019, 02:39 PM | #3 |
Thanks but you have the sizes reversed. The ground tab on the condenser that screws into the side of the distributer base is the smaller of the two. But thanks the sizes were right and it fits well now
11-27-2019, 07:15 PM | #4 |
As per diagram?
11-28-2019, 09:21 AM | #5 |
The one into housing, what the suppliers call it. Is a copper color. the winged part of the distributor cap is labeled as a body of distributor. I knew what you meant as I also make this mistake still on occasion. Berts has a nice little set of fasteners for the distributor. The others probably do too. here is a link with picture of the coated condenser screw. https://modelastore.com/index.php?ro...&category_id=0
11-29-2019, 12:47 AM | #6 |
