04-06-2016, 06:22 PM | #1 |
how to fix handle on S/W
Belongs to a 31 S.W. The door opens just fine using the handle BUT: mad: What is the best fix for his problem, the handle will not line up. The lock operates, there is a little binding on the lower hinge but that should not have any thing to do with the problem at hand. there also is some wear on the shaft but not to make hang down like this. It has been like this since I bought the car. thanks to all
Richard in New Bern. When everything seems to be going against you, remember that the airplane takes off against the wind, not with it” - Henry Ford |
04-06-2016, 06:34 PM | #2 |
Re: how to fix handle on S/W
That's internal wear. You have to rebuild the latches to get the slop out
04-07-2016, 06:41 AM | #3 |
I have took the handle off put it in a vise to twist so it would be in line with the other one.It is hard to fine door parts for the s/w.
04-07-2016, 06:45 AM | #4 |
The parts inside the latch are worn. It is easy to take apart and weldup the areas to fix the problem and make it like new.
Follow the link below to my website. I have all the information that you need. Enjoy. |
04-07-2016, 10:22 AM | #5 |
Excellent website Kevin!
04-07-2016, 11:20 AM | #6 |
Thanks! Used to have more then comcast shut down their web serving. I put stuff back up when I have time and think about it. I have 2 small boys so that does not happen often. |
