Old 05-07-2014, 08:39 AM   #1
Blownflatheaddeuce
Blownflatheaddeuce's Avatar
Default Stock valves spring pressure qun
Hey guys, whats a stock spring put out at the normal installed height in a 21 stud?
What shims would be needed to get the stock spring to 50-60lbs?
Just curious.....
Thx
BFD
Blownflatheaddeuce is offline   Reply With Quote
Old 05-07-2014, 12:42 PM   #2
Pete
Pete's Avatar
Default Re: Stock valves spring pressure qun
Just curious.....
Thx
BFD
You are going to have to check it in the engine you have. At this late date none are going to be the same let alone factory specs.
An adequate spring pressure checker can be improvised with a drill press and a bathroom scale.
Old 05-07-2014, 02:18 PM   #3
Ol' Ron
Ol' Ron's Avatar
The book calls for 37 to 45 depending on the book.
Old 05-07-2014, 03:47 PM   #4
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
If I remember right, and I don't remember much anymore, 42# at 2-1/8in. A .060 shim will bring it somewhere around 55#. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 05-08-2014, 01:27 AM   #5
Blownflatheaddeuce
Thanks fellas that a good guide, I will check it int the engine/with scales.
BFD
