05-15-2012, 01:52 PM | #1 |
Oil,,,???
I recently purchased my first Model T. I was told to use straight 30w oil in it. Is there any reason that a 10w30 blend could not be used.??? Thanks for your time. Rick S...
05-15-2012, 02:03 PM | #2 |
Re: Oil,,,???
Sure, you bet, a multi weight 30 is OK, in fact any good oil in the T, the synthetics cost more, but also foam and froth less in the splash system of the Ford.
05-15-2012, 02:20 PM | #3 |
Re: Oil,,,???
...But for a original splash oiling system in a T, you can go any heavier then 30w oil. Thicker oils can't get into the bearings and can cause damage to the Babbitts...and in a real hurry too!
When I was younger and not "enlightened" in this area yet, I decided to switch to 5w40w. After my first and only trip with that oil in the crank case.....ALL my rods were loose (indicating bearing wear). I readjusted them and put the 30w back in....never had the rods come loose again.
MrModelT 1926 Model T Roadster http://www.jalopyjournal.com/forum/s...d.php?t=308741 |
05-15-2012, 02:21 PM | #4 |
Re: Oil,,,???
Hell of a hard time starting with straight 30 in the cold weather. Went for 10-30.
05-15-2012, 04:09 PM | #5 |
Re: Oil,,,???
My dad was an engineer for EMD ... Electro-Motive Division of GM and swore by 10W year round. He really understood lubrication BTW... It didnt wear off on me tho... I run 70W Pennzoil aircraft oil in my H-D. I run 30W in the T ws
05-15-2012, 05:27 PM | #6 | |
Re: Oil,,,???
I plan to run 30W non-detergent oil in my new T motor for the first 500 miles (break-in) then switch over to full synthetic (Amsoil) as recommend by those who built my engine.
